12-02-2007, 02:18 PM | #1 |
Quarry Creeper Join Date: Mar 2006 Location: ft. collins
| DDsuper2 chassis clod rebuild
So this is the latest version of my super rig. Performs good and there are improvements coming. I will be going to 123 battery packs to increase wheel speed. A BTA steering setup is in the works for the front. And Moab XL's are in the near future. A new body is needed as i just adapted an old lid for the rebuild. Specs and pics below. Chassis: one off prototype DDsuper2, designed to allow full droop or full sprung. 1/8" aluminum sideplates with ABS belly plate. Mine is set up at about 30% droop with internal and xternal springs. This allows for adjustable articulation, ride height, and shock angle options. Limiting straps are used to keep articulation to about 60degrees. Wheelbase: 18" Belly clearance is around 3" depending on preload. Specs: Integy 55t, mamba max ESC, TQ3 radio, castle creations BEC, Towerpro 1/4 scale servos (huge), Thundertech CVD's, JPcustoms aluminum knuckles on front, 110mm shocks from JPcustoms, tired moabs on narrowed beadlocks, custom Roll Six aluminum hex adapters, Skippy's Getto Fab servo mounts. Last edited by dystance; 12-02-2007 at 02:24 PM. |
12-02-2007, 06:45 PM | #2 |
Pebble Pounder Join Date: Sep 2007 Location: Fallbrook
n ice looking rig, what u think it weights ready to run?
12-02-2007, 11:15 PM | #3 |
She rolls at around 11lbs.
