12-03-2007, 09:41 PM | #1 |
I wanna be Dave Join Date: Mar 2004 Location: The Haunted Forest
| JP Knuckles w/ Integy Tubes? Problems?
Anyone know if there are problems mating the JPcustoms Knuckle-pack knuckles for CVD's with the Integy Aluminum C's/Tubes? After fitting both bearings in the knuckle, they wont pivot smoothly. It's like the bearings are too wide, or the Integy C's arent exactly to spec. Same issue on either side. Any thoughts?
12-03-2007, 09:45 PM | #2 |
Could be you have the old bearings that did not fit. He had new bearings made that he was supposed to send out to everyone that only got the singles.
12-03-2007, 09:58 PM | #3 |
The thinner Bearings go on the Inside of the knuckles. You have the New inner bearings. My guess is that you have the thinner bearings on the outside instead of in the inside. Try switching the bearings around.
12-04-2007, 07:22 AM | #4 |
RCC Addict Join Date: Mar 2007 Location: des moines
mine didnt fit eather so I put some washers I had behind the axle c and then put the screws back in and locktighted them seems to be working fine now I have ran it like this for 5 maybe 6 comps
12-04-2007, 12:49 PM | #5 | |
thanks, ryan | |
12-04-2007, 06:51 PM | #6 |
So I measured all the bearings, and they are all the same- 8x22x7.
12-04-2007, 06:59 PM | #7 |
12-04-2007, 08:10 PM | #8 |
Rock Crawler Join Date: Sep 2007 Location: 42N 88.02W
Recently I've put together several sets of JP knuckles and Integy tubes, zero problems, but as run2jeepn says the inner bearings are thinner, 6mm, versus the outer bearings at 7mm.
12-04-2007, 08:12 PM | #9 |
Oh yeah, using the Thundertech CVD's too. BTW, awesome knuckles JP!
12-06-2007, 09:24 AM | #10 |
Newbie Join Date: Nov 2007 Location: rockford
I ordered 4 JP knuckles and only got one 8x22x7 bearing per knuckle. Inner bearings would help with slite woubble. I hope I can order these. This is my first post on this site. Great site, great info, has been tons of help as Im new to this.
12-06-2007, 09:34 AM | #11 | |
My Super is still running just one Bearing and I have never gotten any wobble from it. | |
