Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Another take on high clearance axles..
Old 01-09-2008, 12:50 AM   #1
Default Another take on high clearance axles..
Well I got inspired by cspyy to hack and reshape my clod axles, I've had these axles for about ten years and for about 5 of those they've been on my crawler, so it was kinda hard for me to take the dremel to um'. But I soon got over that and started cutting away.
I didn't want to completely bond the cases together because I like to grease the gears often, my plan was to try to get rid of as much bulk as I could.
It took some shaping and trimming but seems to be good, I still need to stitch the pieces together and fill in some of the gaps, I also want to shave off as much material as I can off the bottom to get some more clearance.............And of course do it all over again for the other axle
Here are a few pics so far.
Thanks for looking.
guest is offline   Reply With Quote
Old 01-09-2008, 06:03 AM   #2
wow you went up past the bottom axle tube mount! hope that works out
btw, my cases arent bonded together, they come apart just like stock
way to hack em up
cspyy is offline   Reply With Quote
Old 01-09-2008, 07:44 AM   #3
hope that stays strong
mickrcarver is offline   Reply With Quote
Old 01-09-2008, 11:49 AM   #4
way to hack em up
Thanks, I must have over looked your design. my mistake.
I hope it holds up too....I guess theres only one way to find out....
Old 01-09-2008, 03:08 PM   #5
Wink
It will be fine for awhile... in '06 I ran a 2.2 to the state championship with no bottom on the case at all (cut flush with the bottom of the axle tube). I did put a lexan bottom on (in a similar shape that you employed) when I took it to nationals (so they wouldn't complain about it being six wheel drive) that truck did well finishing 3rd in the nation... never broke a gear or a case cut like this (on a 2.2).
Chad-
grover is offline   Reply With Quote
Old 01-09-2008, 04:01 PM   #6
Chad-
3rd in the nation..damn!!, I'll be using these for a 2.2 setup. Do you have any pic's of your axle or even a pic of your rig?
Thanks...
