| | #1 |
| Paypal....arghhhh!! ![]() Join Date: May 2006 Location: HONDURAS...ROCK HEAVEN
| Hey guys question for the ones that have already built their rigs, i have almost finished mine(build thread coming) and i noticed when assembling the tranny it was a little hard to turn by hand, but i thought it was because of the gears bieng new and all, as i finished the build(wheels, body are unfinsihed still) i felt as if the whole drivetrain is a little hard to turn, i tried the electronics and it sounded ok, but i have a goat system moving this rig, so basically i just want to know what you guys think, is it normal for this kind of tranny? |
| Sponsored Links | |
| | #2 |
| Rock Stacker Join Date: Sep 2006 Location: HOOPER
| Mine felt a little stiff as well as my axles but the more i thought about it every tamiya i have ever built has been the same. Im running the stock can with a rooster crawler esc and a 2300 mah nicad and I got about 35 min runtime checked the motor for extra heat a couple of times and everything felt fine. I think thats just the way they are. |
| | #3 |
| TEAM MODERATOR ![]() Join Date: Jul 2004 Location: Chit Chat
| I think my transmission was pretty free spinning, but the axles were tight. They spun free enough, but not smoothly, a little crunchy. So I ran it. Smoother now. |
| | #4 |
| Newbie Join Date: Mar 2008 Location: spokane
| for anyones help. |
| | #5 |
| Rock Crawler ![]() Join Date: Jul 2006 Location: Northeast
| My axles were a little crunchy as well but eventually spun freely. As far as the tranny goes I initially had that problem only to realize I had place the aluminum motor mount upside down so part A2 wasn't sitting flush on the backside of the mount. |
| | #6 |
| Rock Crawler Join Date: Feb 2007 Location: Peoria, Arizona
| my axles were the same. I think the locking cross pin may cause the axle shafts to bind a bit if you really crank down on them. I noticed the "crunchyness" and removed the pin with the axle assembled and then they seemed to turn more smoothly. I have thought about breaking the axles in with the hand drill method. Also if the motor is installed the tranny will be hard to turn via the outputs because you are turning opposite of the reduction which is like 40:1. |
| | #7 | |
| | #8 |
| Powered by Awesome ![]() Join Date: Sep 2004 Location: Castle Rock, Colorado
| if its tight.. hook it up to a power drill and run it for @ 15 min and see if it loosens up. |
| | #9 |
| Rock Crawler Join Date: May 2004 Location: DFW, Texas
| If it's binding then that's a problem so re check the manual. If there's simply alot of drag then then you may have just added too much grease. I had that problem and wiped some of the grease off and it loosened it up a bunch. You could try just running it as it may loosen up after a battery or two. Axles were a pain also. I spent about an hour shimming the diffs and the best I could do it was still a little 'crunchy'. |
| | #10 |
| Thanks for the replies guys |
| | #11 |
| The axles use a shim behind the input pinion, and I figured that's why those were tight, could be the locker pin is too tight I suppose. In regards to the transmission, absolutely make sure you have the motor plate facing the correct way. The plastic piece A2 in step 24 will sit flush with the backside of the motorplate if everything is correct (they even tell you to note the direction). I used very, very little grease. |
| | #12 |
| RCC Addict Join Date: Apr 2004 Location: 5280
| I just backed off the case half screws a 1/4 turn, ran a few packs through and started to retighten the screws as everything broke in. |
| | #13 |
| Rock Crawler ![]() Join Date: Nov 2004 Location: in a basement in Kalispell, MT
| My transmission wasn't crunchy, but very tight. Had to trim the flashing off the planentaries end plates more. It was rubbing in the transmission housing when screwed together. |
| | #14 |
| Mine is smooth as glass now, only ran 1 pack though it, i had a little to much grease in it. |
| | #15 |
| Newbie Join Date: Jun 2008 Location: Colombia S. America
| For Future reference......... i found when building the tranny on my CR01 that if you do not seat the 2 LARGE bearings on the Spur gear Throughly, it will make the trans difficult to turn over by hand. I disassembled the tranny and reseated the bearings (moved 1/32") and re assembled the tranny.......... Smooth as glass..... |
| Thread Tools | |
| Display Modes | |
