Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Tamiya CR-01
Thread: CR01 Diff possible issue
Old 05-13-2008, 10:42 AM   #1
Default CR01 Diff possible issue
Hello everyone
Just got my CR01 Yesterday and started the building process last night.
So far all is good but one of the diffs seems to have a tight spot in it. At one point I can hardly turn it by hand. I looked it over and do not see a noticeable change in mesh.
Anyone else run across this?
Know a solution?
dholby5150 is offline   Reply With Quote
Old 05-13-2008, 10:56 AM   #2
i had 1 that was tighter than the other. but after the first battery pack break in period,it got alot better. seems fine now.
TREE68 is offline   Reply With Quote
Old 05-13-2008, 11:25 AM   #3
I had something similar in my new CR-01 and I went back and loosened the locking pin in the differential a bit and re-thread locked it so it was not so tight. I had it in there really tight and I think it was causing the axle shaft to move ever so slightly that it caused the "tight spot" on the ring and pinion. I have not had much chance to run it though, but I did spin it for a bit with the old hand drill to help with break in.
lowslowTJ is offline   Reply With Quote
Old 05-13-2008, 12:14 PM   #4
Just run it, it will loosen up after a couple of packs.
sparky0068 is offline   Reply With Quote
Old 05-13-2008, 05:07 PM   #5
Did you lock the diff? If so, you probably screwed the pin in too tightly. Put thread lock on it, thread until you feel it bottom out, and then back out 1/2 to 1 full turn. Let the thread lock dry and assemble.
Larrio is offline   Reply With Quote
Old 05-13-2008, 05:23 PM   #6
Originally Posted by Larrio View Post
Did you lock the diff? If so, you probably screwed the pin in too tightly. Put thread lock on it, thread into you feel it bottom out, and then back out 1/2 to 1 full turn. Let the thread lock dry and assemble.
I have exactly the same problem. Both axles have a real tight spot - I can barely turn either of them by hand. I've backed the locking pins out and it doesn't seem to have any effect. Definitely feels like a gear mesh issue - but like the OP, I can't see any problem with the teeth around the rough spot. Hopefully mine loosens up once I start running it.
gordb is offline   Reply With Quote
Old 05-17-2008, 08:31 PM   #7
Well after running a couple batteries through it. All is well.
Thank you for the help all.
Old 05-18-2008, 01:43 AM   #8
with all the tlt axles i have built and my hi lift as well as my tlc i have had this problem more then once. im experience its just a matter of breaking in the new gears.
twisted is online now   Reply With Quote
Old 05-18-2008, 07:11 AM   #9
I have noticed the same thing last night building mine. With the diff locking pine out they turn nice and smooth and with it in it catches a little I too backed my pin out a little and it got better and then ran them a little on my cordless drill and they got even better.
Tamiya Cowboy is offline   Reply With Quote
Old 05-28-2008, 09:55 PM   #10
thank you guys soooooooo much lol. i have been rebuilding this thing for a looooong time. i thought i messed up or had a bad kit. i am about to run it for a little bit and see how it goes. hopefully it goes as plan!!
cj7fanatic24 is offline   Reply With Quote
