| | #1 |
| Newbie Join Date: May 2008 Location: Belgium
| Hi, this is my first post , let's make it a good one ![]() I changed the position of the shocks , like em better this way , makes for a better crawler in my opinion. In the stock setup the shocks ( as they where mounted on the side ) sometimes hit rock , limiting my crawling ability, and if pushed further may be damaged along the line. Hope u can see what i did from the pic's , the rear shock's may or may not fit also on the inside , haven't tried yet. some pro's & con's Shock travel is limited , they don't travel all the way, more at the end. Torque twist hasen't improved , may have made is worse :-) But i do have : Improved ground clearance in the middle, the car is a bit higher more flex more flex and more flex without damaging or stressing out parts, the shock's never bottom out, i left the torsion bar system in ( without torsion bars ) to act as a bump stop. the shock's are protected and out of the way. In my setup i changed the springs from front to back as the front was too stiff and the rear too soft , and that's why i'm not using the rear torsion bar anymore. Grtz, tell me what u think, if you want to know how... let me know. ![]() ![]() |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: May 2008 Location: San Jose
| You now have a 8 link sup. sys.. The shock will snap at the cap with this set up. |
| | #3 |
| | #4 |
| Rock Stacker Join Date: Mar 2008 Location: San Carlos
| | #5 |
| Tried to fit the rear shocks on the inside today, it's a no go , they fit but touch the upper link rod, so i'm gonna leave as is, wouldn't make a difference anyway just looks. And believe u me , if my setup would be bad in anyway i wouldn't do it, i paid for it too ya know. Anyway it won't be long before i get to test it against a stock cr-01 , keep you posted. the torque problem is kinda solved since it's a speed related thing and i'm now running a novak 55T with a 19T pinion. |
| | #6 |
| Newbie Join Date: May 2008 Location: dallas
| hey man i really like what you did to ur cr-01 |
| | #7 |
| Detail pictures on the "how-to" part. first of all : soft springs in front and stiff in rear, works better on my setup second : i swapped some shorter bolts for 2 "15mm" bolts and 2 "12mm" ones. The rear : pretty simple i guess, you can see where the bolt goes , same as stock but reversed with spacers on the inside. Notice that the links ( all 4 ) moved up a hole, remain stock otherwise. ![]() The front : Again not so difficult, you can see where the top bolt goes ( 15mm , didn't have 12mm anymore ) , bottom bolt is again the 22mm with spacers on the inside ( i'm lazy like that :-) ) . The shock is reversed as you can see, again the link moved up a hole, AND !!! on the otherside of the link it ALSO moved a hole to prevent lockup when fully stretched. important this shit :-). ![]() Another picture of the front, a bit blurry sorry about that. |
| | #8 |
| PapaGriz Yo ![]() Join Date: Apr 2004 Location: Planning
| Nice mod El Barto. Did you need to go to a thicker oil since the shocks are more laid down? I used to run 40wt. |
| | #9 | |
might be a solution to the sweatty shocks or maybe i'll upgrade to nicer shocks. Grtz | |
| | #10 |
| thank a ton man. i really appreciate it |
| | #11 |
| A small vid of my LC http://nl.youtube.com/watch?v=Vqof4srBoWw my test course http://nl.youtube.com/watch?v=rcDlJ6ScOP8 Grtz! |
| Thread Tools | |
| Display Modes | |
