06-08-2008, 12:25 PM | #1 |
Newbie Join Date: Jun 2008 Location: France
| Wheel and Shocks question from Paris, France
I there! I am a freshman from France where RC crawling is breaking trough You guys are a bit advance on the rock crawling question so I do have some (questions) for you I bought a BJ 40 from Tamiya and already changed and lot of things (motor, speedo, links, planetary, servo beds, shocks arms) but still have 2 major problems: I would like to change my crappy wheels for aluminium ones from RC4WD. Can you please help me help me with the size, I thing 2.2 is ok but not really sure it will fit my tires Second and more important: shocks absorber there are no options at the moment and the originals are the crappiest thing i've ever seen. What should i get????????????????????????????? Thx in advance for your help |
06-08-2008, 01:37 PM | #2 |
Quarry Creeper Join Date: Jun 2007 Location: bay area
the stock tires are 2.2 so any rime you get will work as long as its 2.2 |
06-08-2008, 05:53 PM | #3 |
Newbie Join Date: May 2008 Location: Jersey Shore BAR's (BIG ASS ROCKS)
i gave these a shot and fit fine. 4" or 101 mm eye-to-eye, low cost up grade with coil-over spings if needed and different sping rates(white,yellow and green, white being the lightest). I removed canti setup and attached to side frame and same spot as original ball cups on axles http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAMU6 shocks http://www3.towerhobbies.com/cgi-bin...?&I=LXAMU4&P=M note: bushings need to be drilled to fit stock screws, i used to to attach to upper ladder frame and used plastic "D" parts #5 as washer on top of shock asm. just use stock ball cup for lower mounts at the bottom. good luck and have fun |
