06-22-2008, 09:11 AM | #1 |
Rock Stacker Join Date: Jun 2008 Location: Israel
| wb question.
wheel base issue ... i cant get over it , it bothers me . i'm not trying to fix it right now because i'm still waiting for my esc and battery and dont want to change anything before i drive it stock for couple of times. has anyone tried moving the upper spring assembly and connecting rods one hole inwards ? will this position the rear wheel where it belongs ? |
06-22-2008, 03:30 PM | #2 |
Quarry Creeper Join Date: Aug 2005 Location: newport
I moved the lower links forward on the chassis 1 hole and cut 5/16ths off upper link I moved back 1hole on the servo plate Didn't move the cantilever because moving it forward would result in limited movement as the arm would contact the frame when pivoting. |
06-23-2008, 04:13 AM | #3 | |
wouldnt moving the cantilever one notch will create the same situation as in the front cantilever (no problem of contacting the frame there) ? have you tried it and actually faced the problem ? Quote:
06-23-2008, 01:27 PM | #4 |
yes that's why I have it at the orog location
06-23-2008, 01:46 PM | #5 |
Rock Crawler Join Date: Feb 2008 Location: Golden Corral getting Fat
you need to limit the travel anyways if you use or are going to use in scale comp there is too much travel for the Rules
06-23-2008, 02:28 PM | #6 |
i see , thanks . you have saved me the trouble of trying that myself. anyway , great rig you got there . |
