07-07-2008, 09:52 AM | #1 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
| Axial wheel issue FYI
Mounted some Axial beadlocks on my cr01. Stock plastic hexs started to slip in the wheel. So I installed Axial aluminum hexs. Cured the slipping, but I still have to tighten my wheel nuts every 5 to 10 minutes. 2-3 more threads on the stub shafts would have been nice. Been running without washers hopeing it would have been enough, negative. Time for locktight.
07-07-2008, 06:20 PM | #2 | |
I wanna be Dave Join Date: Dec 2007 Location: Florida
07-07-2008, 06:28 PM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
I do not think I would use locktite...If the hex sticks out from the wheel then I would sand it down until it is flush...you can sand down the inner side of the hex without losing any of your pin recess area, or sand both sides until you get what you need for your wheel nut...just my 2 cents
07-07-2008, 06:58 PM | #4 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
X2 that id sand the hex down as well
07-07-2008, 10:27 PM | #5 | |
07-08-2008, 08:03 AM | #6 |
Quarry Creeper Join Date: Aug 2005 Location: newport
could try the thin hex's that come w/ rpm wheels or tamiya aluminum 4mm hex's |
07-08-2008, 10:09 AM | #7 |
Pebble Pounder Join Date: Dec 2006 Location: nampa
I havn't had any issues with mine, i ran the stock axial rims the changed to the proline beadlocks and they have never came loose if anything when i change the wheels it's almost impossible to get that wheel nut off. but try sanding the front of the hex it should give the the little extra you need or i know hpi makes thinner lock nuts the run like 5 bux for a large pack of them.
