08-18-2008, 11:07 AM | #1 |
RCC Addict Join Date: May 2008 Location: Green Bay
| Parts tree question
I am looking for the parts that hold the springs on both the top and bottom of the suspension. I need them for a scale build I am working on. Can anyone tell me what part numbers or tree they are? Thanks for the help |
08-18-2008, 01:44 PM | #2 |
Quarry Creeper Join Date: May 2008 Location: Franklin
If no beats me to it. I will post the numbers when I get home from the parts list. Later Goz.
08-18-2008, 02:18 PM | #3 |
B Parts (9005888 ) has part of the lowers, C Parts (9005889) has the uppers. D Parts (51328 ) has the part that keeps the spring in place, and the part that attaches the lower to the axle parts. You'll need two of each. Looking at this stuff in front of me, I think you're in for a pain in the neck getting this adapted to anything else. |
08-18-2008, 03:57 PM | #4 |
Newbie Join Date: Jul 2008 Location: Westminster
| Other option |
08-18-2008, 04:59 PM | #5 |
Thanks everyone. I need them to build a scaler....Jeep KJ. I was hoping the CR-01 parts would work. I may have to keep looking if these don't.
09-10-2008, 10:21 PM | #6 |
Quarry Creeper Join Date: May 2006 Location: Pirkkala, Finland
Hey... I'm seriously thinking of getting an CR-01. I've previously had Axial (pretty much built everything possible to it, so it's not an option anymore). Question 1: Does CR-01 has bad twist? Question 2: Comparing about stock ax-10 and cr-01, which one beats the other one? Can you crawl with cr-01 or is it really just a scale truck? Are there any videos available where there'd be 2.2 crawlers and cr-01 on the same competition? I'd really like to see what this truck can do before I buy it. Thanks! |
09-12-2008, 04:05 PM | #7 |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
The CR-01 and Ax-10 in my opinion ( I have a cR my friend an AX) are both very capable crawlers, but I dont think one is "better" than the other. They crawl very differently, but usually end up at the top of the same hills and over the same obstacles. How we get the up or over differs but that's what makes it interesting. |
09-20-2008, 01:52 PM | #8 |
Now that I've driven the truck for almost a couple days in various conditions I've noticed it's not that good a crawler out of the box (which was obvious and could be noticed from the images, so not that much a surprise). Way too top-heavy. So... Has anyone put any weight in the wheels to keep them down? If, how much? I'm using 3S 1300mAh LiPo pack, so it should not be too heavy ;). I've put the heavy spring to the rear and soft to the front, using stock shock oil. Should I change it? If, what'd be a better choice? |
