08-22-2008, 07:10 PM | #1 |
Quarry Creeper Join Date: Apr 2008 Location: sanford
| gears went bad
check this out guys thsi is what happedwhen my set screw backed outof my pinion gear when the truck was under water pic of new on bottom old on top |
08-22-2008, 07:23 PM | #2 |
RCC Addict Join Date: Sep 2007 Location: Western ND, Bakken central
DAMN nice carnage, anybody else have this happen |
08-23-2008, 05:13 AM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
Did you us loctite on the set-crew ????
08-23-2008, 09:46 AM | #4 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
If the pinion set screw backs out, you loose drive. Looks more like a worn out cheap aluminum pinion?
08-23-2008, 11:36 AM | #5 |
Rock Stacker Join Date: Aug 2005 Location: Wintersville
nope, cant say thats ever happened on my CR-01 im gonna have to go with the last post "poorly made pinion"
08-25-2008, 02:56 AM | #6 |
Newbie Join Date: Jul 2008 Location: 'ON THE ROCKS'
i would agree - badly made, or cheaply made. Are you using the standard TAMIYA 20T pinion?? |
08-25-2008, 07:54 AM | #7 |
Quarry Creeper Join Date: Aug 2005 Location: newport
those tamiya pinions are to soft a material and wear easily. Get a good quality pinion from Robinson Racing here is the link to a 20, but they have many others http://www3.towerhobbies.com/cgi-bin...?&I=LXEX43&P=7 |
08-25-2008, 08:28 AM | #8 |
I wanna be Dave Join Date: Jul 2007 Location: Within The Machine,,,
make sure you use 48p metric,,not standard,,i ran into a problem a while back with the wrong pitch,,standard will work for a while ,,very noisy,,
08-25-2008, 05:15 PM | #9 |
08-25-2008, 05:20 PM | #10 |
Make sure your gear mesh is set properly as well....
08-26-2008, 07:12 AM | #11 |
the link I posted above is the correct metric pitch gears from Robinson. They also fit most Tamiya touring cars and such so they shouldbn't be a problem to find.
