08-24-2008, 07:57 PM | #1 |
Newbie Join Date: Aug 2008 Location: ..........................
| popping noise fwd. to reverse
going fwd stop then to reverse there is a popping noise....the same happens the other way
08-26-2008, 03:04 PM | #2 |
Rock Stacker Join Date: Sep 2006 Location: Liberty
Check you gear mesh on your motor also check for missing teeth. If that is ok i would take the axles off and see if you can narrow it down to an axle or the transmission. check the drivelines to see if 1 is starting to come apart.
