10-10-2008, 12:05 AM | #1 |
Newbie Join Date: Aug 2008 Location: Chile
| HELP!!!!!!! PLEASE!!!!! CR01 in trouble.
I got my cr01 recently and Im experiencing some problems with the way it runs, so far my set up is: Novak Rooster Crawler / 55t novak motor 3600 mah 6c weighted tires (proline beads/ mashers 2000) well the problem is that when I give it some throttle the wheels dont spin correctly they "stop" at times so its like its accelerating and breaking , its not like it breaks but you can tell that its not running correctly. I reassembled the differencials and the tranny and they seem to be ok, could it be the motor? or shafts?? has anyone had this problem?? any solucion to this?? all coments are apreciated. this is driving me nuts. |
10-10-2008, 12:15 AM | #2 |
Rock Stacker Join Date: Apr 2008 Location: Vienna
hi i have the same problem with a e-savage. i think my problem comes from a melting tamiya-battery connector. both connectors really got hot one day, and it was really heavy to disconnect the batteries, because of the melted connector. do you have any heat-problems on your car? |
10-10-2008, 12:48 AM | #3 |
Coral Crawler Join Date: Oct 2004 Location: Myrtle Beach
What kind of "stopping" is it doing? Need some more details, does it seem like the drivetrain is binding somewhere or does it seem like the motor "sputters" due to breaks in the electrical current somewhere within the electronics/wiring chain? Are you using a new motor/esc setup or have they been used before and if so, what kind of use did they go through? How are you connecting all of you're wiring, solder? wire connectors? twist-n-tape? Also, how frequently does it occur? A few times per every foot or two of travel or just once and a while? Does it seem to have a consistant pattern to it or does it just occur once and a while whenever it feels like it? Well, I just saw you're pic's in the mud, lol, was the problem occuring before the romp through the mud or just after? Last edited by beachbum; 10-10-2008 at 12:57 AM. Reason: because it's late and I can't spell worth a damn |
10-10-2008, 02:55 AM | #4 |
Pebble Pounder Join Date: Jul 2008 Location: Tamworth, England.
MY CR is an absolute git when first switched on, it coughs and splutters for a minute or so. It has had 3 different motors and 3 different speedo`s and it is always the same. I think it is the receiver, and or the fact that my aerial is inside the bodywork. Think I will have to make a whip aerial and mount it outside the shell!
10-10-2008, 10:33 AM | #5 |
RCC Addict Join Date: Jun 2008 Location: Wasilla
im not that familiar with the rooster esc, but i know my sidewinder does the same thing when its setup for a brushless motor and your trying to run a brushed motor. - tre |
10-10-2008, 11:36 AM | #6 |
Its pretty constant and it doesnt sound persistant ( the motor or tranny)
10-10-2008, 12:16 PM | #7 |
Rock Crawler Join Date: Feb 2008 Location: Golden Corral getting Fat
check lipo dut-off to see if it is on? maybe?
10-10-2008, 01:29 PM | #8 |
Quarry Creeper Join Date: Feb 2006 Location: Surrey B.C Canada
Pull on the brushess enough to keep them in the guides but almost all the way out and let them snap back in place Sometimes brushess don't seat on the com. right And if your running tamiya plugs just ditch'em and just get deans Its happened to me Cheers....MJH Last edited by mjh; 10-10-2008 at 01:33 PM. |
10-10-2008, 02:28 PM | #9 |
Im pretty sure its not the tranny nor the differencials, so Im going to check the brushes and change to dean conectors, thanks a lot for the help Ill keep posting updates.
10-10-2008, 05:35 PM | #10 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
I run a 45t with a Rooster Crawler, a JR XS3 with the antenna inside the body. I have not experienced any skip problems with this set-up. I suggest changing battery plugs and hard wiring your motor. Also make sure you have the capacitors installed on the motor. Try to route all your wires so that they are not laying on one another. Hope this helps...
10-10-2008, 05:56 PM | #11 |
This might be dumb but are running the truck close to a internet wireless signal? My clodbuster would freak out, mainly with a punk rc steering computer, so this might not help you. When I ran the truck far away from the house it was fine. Looks like you checked most of the mechanical stuff, so I thought i would chime in with the signal stuff. |
10-10-2008, 07:11 PM | #12 |
I know what you are talking about, but its not that, It feels like the motor isnt running at a constant speed its not a big deal but it can get pretty anoying you know.
