11-02-2008, 06:54 PM | #1 |
Pebble Pounder Join Date: Sep 2008 Location: chicago (now in MD)
| Backyard obstacle
Finally got over it, after a lot of tweaking. Hope you guys like it. |
11-03-2008, 07:48 AM | #2 |
Rock Stacker Join Date: Sep 2008 Location: Connecticut
Nice! Im diggin those tires... Crushers right ? |
11-03-2008, 08:39 AM | #3 |
Rock Crawler Join Date: Jul 2008 Location: grand rapids, bay area, nyc.
looks really cool love the color! what are your thought on the tires? i like the look of them but havent bought because everyone says they're crap... they do well in dirt? im thinking about using them for dirt/mud and having a back up for rocks. thanks
11-03-2008, 08:47 AM | #4 |
Quarry Creeper Join Date: Sep 2008 Location: South Glens Falls
Great job on the body!! RC4WD tires? Almost as tall as the Tamiyas? Like the photos. |
11-03-2008, 11:58 AM | #5 |
11-03-2008, 02:03 PM | #6 |
11-03-2008, 03:29 PM | #7 |
Rock Crawler Join Date: Dec 2005 Location: Mesa
| The reason for the suck factor is that the lugs are too close together, not enough space between them. When they conform to the rock, the lugs close up the gaps leaving a slick area that doesn't have any biting surface. Take a lot of time and dremel open the grooves on the center blocks a little bit and they'd be OK.
11-03-2008, 05:53 PM | #8 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
These are the best off road tire. Hands down. They suck for rock crawling but for a scale all around tire they can't be beat. |
11-03-2008, 06:46 PM | #9 |
steve: thanks, yes rc4wd crushers. enforce: thanks, i got sold on the looks really cool, it really does no good on rocks, the lugs close on compression and becomes slick. would really love to test them on mud though. jeephead: enforce is correct, its really tall. the body is on the highest mount on the posts, the front has a lot of flex coz of the dual rate shocks, but the rear is stiff because of the scale shocks(the internal spring is hard) i would change them but i'm holding out for a new 2.4ghz rx. o yeah the rear tires rub on the body on flex and so does the front. thanks for appreciating. Mriswith: that's a great idea. i might try it thanks. pwccrawler: thanks man |
11-03-2008, 08:24 PM | #10 | |
sweet thanks for the feedback ill be getting a set of those asap for mudding around and some panthers for the rock! | |
11-03-2008, 08:27 PM | #11 | |
sweet thanks for the feedback ill be getting a set of those asap for mudding around and some panthers for the rocks! | |
11-04-2008, 02:43 AM | #12 |
Rock Stacker Join Date: Nov 2007 Location: norway
RC4WD told me that they are coming out with some softer internal springs for the scale shocks in like a week or so. I am also using those shocks on my CR-01, and the stock ones are too hard for a sensible flex. I ran RC4WD 2.2 Rock Crushers (soft compound) on mine first as well, but swopped 'em for RC4WD Mud Slingers (soft compound also). I am currently rebuiding my axle/link/shock set up, so haven't tried ''em yet. Nice work on the body! |
11-04-2008, 11:04 AM | #13 |
enforce: glad to help simensays: thanks, yeah thats great news on the springs, i was thinking of the same thing on the mudslingers and a set for rocks too. wanted to extend my wheelbase more but the punisher shafts have limited length for it. do you still use cants? i moved my rear cants in (close to the upper links) so i could use still use them. |
11-04-2008, 12:52 PM | #14 |
Nope, I removed the cantilevers, and am currently rebuilding the suspension setup quite a bit. I am cleaning up the whole enchilada, and removing as much parts as possible for optimal performance and looks. More here I am making a custom upper link mount, that also serves as a shock mount for the rear (not the modded servo tray in the pics), and plan on shortening the WB a little. If you want to extend the WB - try swopping the drive shaft with a High-lift rear shaft. You can modify it like shown here to fit your desired length. Last edited by simensays; 11-05-2008 at 08:43 PM. |
11-05-2008, 03:49 PM | #15 |
simen: thats a snappy rig you got there. thanks for the info, appreciate it. i did shorten my wb one time, but getting over that obstacle made it roll over so went back to making it longer at least 12".
11-05-2008, 05:27 PM | #16 |
Quarry Creeper Join Date: Aug 2008 Location: UK
I went for Crushers based on looks too. I wanted scale, and I heard from somewhere that they cope quite well with snow. Looking forward to finding out in a couple of months. |
11-05-2008, 11:45 PM | #17 |
That's an awesome looking truck! I want one of these CR-01s bad!
11-10-2008, 11:29 PM | #18 |
simen: is your thread missing? i tried to follow your mod on the links, here's what i did: |
11-11-2008, 02:29 AM | #19 |
Quarry Creeper Join Date: Jul 2008 Location: SWEDEN
Looking good but a question. Whats the benefit of rising the upper links on the axles ?
11-11-2008, 04:33 AM | #20 |
Looks good Jadama! Did you remove the inner springs from the shocks? Yeah, I accidentally deleted the whole thread and haven't bothered to write it again. |
