11-26-2008, 10:56 PM | #1 |
Rock Stacker Join Date: Sep 2008 Location: Connecticut
| Gearing with an Integy 35t
I am thinking of picking up an Integy 35t motor, can you guys recomend a good pinion to go with it ? I am thinking a 16 or 17 tooth would be good? Lemme know what you guys have had good luck with !
12-03-2008, 10:13 AM | #2 |
Pebble Pounder Join Date: Apr 2008 Location: yakima
Hmm well ill take a stab at this. I had fifty five turn with the stock pinion. I would drop two teeth off that. I currently have a 35 turn but my cr-01 had an R2D. I think it has a 15 tooth pinion now and it rips along pretty good. Thats the best I have for you.
12-04-2008, 12:23 PM | #3 |
Pebble Pounder Join Date: Oct 2008 Location: L.A. lower Arkansas
I have an integy 35 turn with the factory pinion and it runs fine. If you are curious it is not much slower than the factory 27 turn but is much better on my small rock course. Better throttle control.
12-05-2008, 07:47 AM | #4 |
Newbie Join Date: Jun 2007 Location: Chicago
Same here, running a 35t with stock gearing, works perfect IMO.
12-05-2008, 10:04 AM | #5 |
Newbie Join Date: Oct 2008 Location: Nerk, Ahia
Oh, may I perform a minor hijack here? I am getting the Rooster/55T bundle, what shoud I use for that in a pinon. The stock 20T? |
12-05-2008, 10:43 AM | #6 |
RCC Addict Join Date: Sep 2008 Location: Philadelphia, PA
With the stock pinion (19T?) you still get some roll on steeper inclines even with the drag brake on the Rooster. You could try one with less teeth and eliminate that.
01-13-2010, 09:27 PM | #7 |
Pebble Pounder Join Date: Dec 2009 Location: Ottawa
What do you suggest for a 45T Tekin motor ?
01-14-2010, 05:49 PM | #8 |
I've switched mine up recently and I have a 21T pinion on a 35 turn Tamiya motor. Its working pretty well.
01-15-2010, 12:37 PM | #9 |
Rock Stacker Join Date: May 2008 Location: seattle
fraxture I have that same setup and i love it i have the stock pinion and it is amazing i actually can out pull a buddy of mine in his axial dedicated crawler! (we tied the axles together and said 123 and i pulled on his rig like a B*tch in forward and reverse gears) i will always use that setup! c |
