02-05-2009, 11:34 PM | #1 |
RCC Addict Join Date: Jan 2009 Location: ?????
| servo i getting my last needed parts, and i got my servo today its a hitec 645 i think is the number and it came with "just" the servo, do i need any other parts or is everything needed included in the cr01 kit? any info will help, thanx........ |
02-06-2009, 01:10 AM | #2 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
| Thre kit has a servo saver and different inserts, there should be one for a hitec in the kit, but your servo is a bit weak , most are running 180oz + , I run a 200oz airtronics in the front and 1800z tower pro for the rear.
02-06-2009, 07:47 AM | #3 |
so thats not a very good servo? quite a few people on here steered me in that direction, im not looking for the best rite now i was ona budget and just wanted to get it rolling. but soon im going to upgrade a few things, what servo would reccomend any why? if you dont mind my asking, thanx.........
02-06-2009, 07:55 AM | #4 |
Quarry Creeper Join Date: Aug 2008 Location: UK
| I don't wish to contradict Joat, but I had problems using the stock servo savers with Hitec servos. I found that the two different fittings included were both wrong for my Hitec 645. I may have been unlucky, but Tamiya are pretty good at consistent forming of their parts, so I'd be surprised if there was much variation.
02-06-2009, 09:57 AM | #5 |
Rock Stacker Join Date: Jun 2008 Location: Israel
I'm using the stock cr01 servo saver on an hitec 645 and it works fine.
02-06-2009, 11:00 AM | #6 |
| so where i got only the servo and no other parts with it all i need is included in the cr01 kit? how does the 645mg work for you vtt? |
02-06-2009, 11:43 AM | #7 |
Rock Stacker Join Date: Sep 2006 Location: Liberty
I have a 645 and it works fine it is not the strongest or the fastest but it works. If you get bound up in rocks a stronger servo will be better. I use mine as more of a scaler lite crawler and it works. As far as the kit servo saver's they is not on for hitec they will work for a while but eventually will strip the plastic.
02-06-2009, 12:14 PM | #8 | |
I'm using this servo with the stock tamiya hardware for 6 months and no stripping yet. (and i use it hard) its not the strongest servo but it works just fine. | |
02-06-2009, 01:32 PM | #9 |
Rock Crawler Join Date: Sep 2004 Location: South Orange County
I run that servo and its just fine. It gets the job done. |
02-08-2009, 07:31 PM | #10 |
I use the 645 and its fine for me, i stripped on of the stock horns for the futaba and now using the one meant for airtronics just fine. its mainly just a bit slow
