04-10-2009, 06:39 PM | #1 |
Newbie Join Date: Mar 2009 Location: Belgium
| Chevy cr-01
Hello can somebody tell me what speed control and motor is the best for the CR-01 (novak goat , rooster .....) now its a 12T dynamite tazer and the stock motor the servo is ok its a hitec HS-5955TG , and would it be possible to install the 3racing axial shocks on this baby? does somebody knows how much weight i have to bring on the front tires?Thank you and greetings from belgium. |
04-10-2009, 07:07 PM | #2 |
04-10-2009, 07:12 PM | #3 |
Newbie Join Date: Jun 2008 Location: Montreal
Salut, I am using the stock motor with the Novak goat and so far it's great(I like the fact of being able to go brushless without having to change esc later), good tork, good control at low rev and good speed when I put it to the floor!... Bonne chance! And congrats on your rig, it looks pretty cool!!! |
04-10-2009, 07:16 PM | #4 |
| thank you
I think i will go for the novak goat set , i installed the 3racing metal driveshafts so its ok i think. |
04-11-2009, 04:44 AM | #5 |
Quarry Creeper Join Date: Oct 2008 Location: Allentown PA
3 racing driveshafts suck! I have a set on my CR-01 and they suck the best ones I read about and just p;aced a order is Junfac they seem to be the best. With 3Racing shafts are they have steel yoks and aluminum shafts and set screw to hold them together I lock tighted them when I got them and after the 3rd pack they started slipping around the shaft (set screw) I drilled a hole through the shaft and all it did was last another 4 batts and SNAP they are not worth the wait and the money spend a little more and get the JUNFACS. Thats my two cents Greg |
04-11-2009, 07:32 AM | #6 |
Hello thanx for the help , can you be more specific about junfac (order nr for the schafts ) and is it possible to let my know your set-up ESC and other goodies so i can learn how to make it go like hell , thanx
04-13-2009, 03:19 PM | #8 |
the junfacs looks sweet and im sure they are better
