05-10-2009, 04:47 PM | #1 |
Rock Stacker Join Date: Dec 2008 Location: Australia
| New CR-01 in OZ
Hey guys, Well its put together and run a few times and I like it! Its all stock for now, but I want to know what adjustments I can do with the canter links to make it flex better. Here are some pics from my front yard on the weekend. |
05-10-2009, 04:49 PM | #2 |
Some more |
05-10-2009, 05:45 PM | #3 |
Quarry Creeper Join Date: Aug 2008 Location: San Jose
You could move the mounting into different holes. You could use the zip tie trick to get rid of slop. You could remove it completely. You really need to do a search with your question. Eeepee, and JIA's threads are a good start. I personally have removed the cantis on mine and converted it to a droop set-up. Others, like minicracker have had good success with the cantis. I guess read up and see what you like. |
05-10-2009, 06:58 PM | #4 |
Rock Stacker Join Date: Feb 2009 Location: Australia
I just removed the rear cantilevers on mine and fitted the short barrel springs. It works really good now and has lots more flex in the rear. I can't remove them from the front or the tyres will rub too much |
05-10-2009, 07:21 PM | #5 |
What about the swaybars?
05-11-2009, 08:15 AM | #6 |
Rock Stacker Join Date: Feb 2009 Location: rockland maine
i would take out the sway bars or stablizers in one of your pics i think i see the rear one is in i would remove the rear one frist and leave the front then tell us what you think im still building mine but i have had more than one crawler befor
05-11-2009, 08:16 AM | #7 |
| I removed both sway bars. Since then I always had a problem with the CR01 leaning too much to the left. I never could figure that one out, and I didnt want to put stiffer springs in the left rear. I was actually about to put the cantis back on, then I decided to try the droop set-up. Since I've had it on droop, I have had no leaning problems, lowered my COG, and have also close to zeroed out the effects of torque twist...Although I still do get the torque twist effect on 50 to 60 degree incline tests. |
05-11-2009, 04:27 PM | #8 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
On mine I left the swaybars in and removed the cantilevers. Then I mounted my shocks from the axle to the chassis. On the rear I raised the upper links at the axle to help with torque twist. I think I have 30wt in my shocks. |
05-11-2009, 04:42 PM | #9 | |
I like this idea, it's like a Currie antirock swaybar for 1:1 TJ's Have you got any pics of the flex you get now? It is better? | |
05-11-2009, 04:57 PM | #10 |
I have no pics, but I must say it does work better with this set-up versus stock... |
05-11-2009, 05:33 PM | #11 |
Cool, well I think I will start with removing the rear swaybar first, then will progress from there. 1rc, do you think your shocks are longer or the same length as the stock ones |
05-11-2009, 06:28 PM | #12 | |
I have both mine in, the stiffer one in the back, I think. Yeah, cause I have softest springs in the back. Then medium sway in front with medium springs in front. | |
05-11-2009, 07:59 PM | #13 |
The shocks are just an old set of Associated 4 inch I had laying around...
05-11-2009, 10:03 PM | #14 |
I like to limit the front articulation but leave as much as I can in the rear . The rear sway will limit the rear articulation . Im no expert in rc but if you leave the front sway in that will hlep the tork twist because when one front tire trys to lift the other takes all the weight which in turn will pull the opposite tire back down using the weight of the truck. I could be way wrong but I would think leaving just the rear in would still let the truck torq twist. I would also think that this would hurt you on steep climes because the sway in the front will help you keep both front tires planted on a clime by making it squat. I would think that the sway in the rear is only going to make the rear squat and front tires lift more but I could be wrong like i say im just using what i know from 1/1 scale cars and drag racing There is nothing wrong with constructive criticism or even corecting me just please use the same respect you would want. So please tell me if you think im wrong or what |
05-11-2009, 11:02 PM | #15 | |
Seems to make sense to me. I did a little bit of a drive around the back yard yesterday with my new set up, rear cantis and sway bar removed, and I didn't notice a lot of torque twist. Have not had the chance to try it on any steep climbs yet. | |
05-12-2009, 04:59 PM | #16 |
I had a play with it last night I pulled out the rear sway bar, it stoped the front from flexing but the back was good. I pulled out the front and rear sway bars, it had great flex but to much torque twist. I put in the rear swap bar and the torque twist calmed down and the front and rear flex are good So I have stuck with that until I can take it for a spin. |
05-12-2009, 05:35 PM | #17 |
Mount your upper rear links on top of your plate and that will help with torque twist as well. If you can raise them up 2 or 3mm thats even better... |
05-13-2009, 02:51 AM | #18 | |
About a month later a 4WD mag here in OZ made a comp rig through the mag and they were doing a rear suspension setup similar to what I had tried. I said to a mate "it will roll over backwards at the first hill it gets to" I was right, first comp, first hill, first big roll. www.youtube.com/watch?v=73ljDXHMRm8 | |
06-28-2009, 10:35 PM | #19 |
Quick update.... Rear Sway bar stayed in, front one came out, Heaps better. Tyre weights fitted, heaps better. I now have lights. A mate liked mine and went and got one of his own. |
07-05-2009, 02:39 AM | #20 |
Rock Stacker Join Date: Nov 2008 Location: Philippines
On my rig I have the Tamiya barrel springs (medium front, soft rear) and the optional sway bars, with the medium bar on the rear and the soft bar up front. Flexes alot better, with just a little more torque twist compared to the stock setup Don't forget to zip tie your cants to get rid of the slop!
