Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya CR-01
Thread: cr-01 build
Old 06-16-2009, 01:15 PM   #1
Default cr-01 build
Just recently built a tamiya cr-01,when i push the truck on the floor manually, it will not freely roll on it's own. there is no electronics asside from the motor installed, is this normal? I don't want to burn out the motor or speed control, any help would be appreciated.
stanpede is offline   Reply With Quote
Old 06-16-2009, 01:26 PM   #2
Mine was the same way, it was my tranny not put together exactly even try reassembling it.
microdot is offline   Reply With Quote
Old 06-16-2009, 01:54 PM   #3
make sure your axles were done right i had to swich my rear around cause they were fighting one was going back and one was going faward
freelife04239 is offline   Reply With Quote
Old 06-16-2009, 02:27 PM   #4
Yes it's normal, you're fighting the magnets in the motor. Take the motor out and then see what it does.
Nate08 is offline   Reply With Quote
Old 06-16-2009, 03:33 PM   #5
it could also be that the pinion and spur gear arent meshed properly. .. . that was my problem. .. .
IDnewcrwlr is offline   Reply With Quote
Old 06-18-2009, 01:25 PM   #6
Definately check the spur and pinion mesh. If its even just a little too tight, it will make the driveline incredibly hard to turn over.
towerdog is offline   Reply With Quote
