02-03-2010, 06:58 PM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: vancouver, canada
| 3racing drive shafts
curious if anyone has tried these out, i am only going to be running a 35t motor max, and was wondering what people thought of them. i have used 3racing items in my TT-01 and been generally happy, (you get what you pay for) they are considerably less expensive than the tamiya ones and the junfac ones. Last edited by cydog510; 02-03-2010 at 10:39 PM. Reason: axels? nope drive shafts. oops. |
02-03-2010, 08:51 PM | #2 |
Quarry Creeper Join Date: Jun 2009 Location: Way down under!!!
Mate, I blew a front drive shaft within 40minutes of running. The pressed-in pin fell out and was lost, as was the square uni. I'm now running GPM shafts and haven't had an issue. They are slightly heavier, but so what, weight and low COG is good, right? |
02-03-2010, 08:55 PM | #3 |
Rock Crawler Join Date: Nov 2005 Location: Livermore
Those are drive shafts not axles. I have not used them, but you should get more replies if you change your thread title.
02-03-2010, 10:41 PM | #4 |
thanks 51504rock, dumb mistake, correction made, i meant drive shafts. sorry. stew, any link for the GPM parts? more weight is all good by me! |
02-04-2010, 07:34 AM | #5 |
Pebble Pounder Join Date: Jan 2006 Location: outside reading, pa
I bought Traxxas shafts from the local hobby shop & shortened them. Cheap and effective, but now im breaking axle parts instead |
02-04-2010, 10:51 AM | #6 |
you got a part #? also, where would i find lead wheel weights? i looked into a fishing tackle shop but only found long and round weights, mind you it was a small shop..... thx for the help. Last edited by cydog510; 02-04-2010 at 11:11 AM. |
02-04-2010, 05:27 PM | #7 |
Cy, Got em on the bay. Link for a current auction attached http://cgi.ebay.com.au/GPM-STEEL-MAI...#ht_1358wt_859 As I said, so far these work fine. |
02-04-2010, 05:31 PM | #8 |
Re lead wheel weights, go to a tyre shop and get a few sticks of mag wheel weights. They cost me a buck each. They are a self adhesive flat weight, you just gotta trim them a bit to fit inside the wheels of the 2.2's. |
02-05-2010, 02:51 PM | #9 |
spectacular! thanks so much for the help stew!
02-06-2010, 09:52 AM | #10 |
Newbie Join Date: Apr 2006 Location: central jersey
go to napa and ask for a box. usually, you can get a box of 30 sticks holding 3oz of weight each. the design varies. I have some that are flat with a larger length/width, and some that are thick with a narrow length/width. |
