04-18-2012, 05:46 PM | #1 |
Pebble Pounder Join Date: Feb 2012 Location: Newfoundland Canada
| What is a tamiya tundra cr-01?
Is a tamiya tundra a cr-01 style or what, im trying to find a shaft to fit my tundra but tower hobbies dont seem to have one? Only for cr-01
04-18-2012, 08:02 PM | #2 |
Newbie Join Date: Nov 2010 Location: Canada
| Re: What is a tamiya tundra cr-01?
Junfac makes a good driveshaft for the Tundra. I run their shafts in my CR-01 and they are great. Heres the link- Hardened Universal Shaft for Tamiya Tundra [J90024] : JunFac.com |
04-18-2012, 08:04 PM | #3 |
Rock Crawler Join Date: Sep 2008 Location: Delta B.C.
tundra is a tamiya hifift chassis
04-19-2012, 10:13 AM | #4 | |
| Re: What is a tamiya tundra cr-01? Quote:
Haha awesome I already have them, i lost the front shaft the other day but I just found it today. They are great shafts but Im having a lot of problems with the set screws and shaft pins falling out. I need new set screws they are mostly rounded off. | |
04-19-2012, 08:20 PM | #5 |
Using Locktite on the set-screws? Are you having trouble with the set screws that hold the shaft pin in? If its the set screw that holds the shaft to the transmission I use these set screws on my CR-01 shafts Axial Screw Shaft M3x2.5x11mm (10) AXIA0175 | eBay Last edited by cr-01; 04-19-2012 at 08:31 PM. |
04-20-2012, 01:19 PM | #6 |
Rock Crawler Join Date: Mar 2010 Location: NRV
wrap some tape on there too or use heat shrink tubing.
04-22-2012, 11:27 PM | #7 |
popped 2 new set screws with loctite on there, so far so good. Good tip DRW on the heat shrink tubing.
04-25-2012, 08:07 AM | #8 |
Newbie Join Date: Apr 2012 Location: Waterford
CR-01 is the kind of chassis it has
What is a tamiya tundra cr-01? - Similar Threads | ||||
My Tamiya Tundra | Racer4Life | 1.9 Scale Rigs | 40 | 06-07-2012 03:16 PM |
Tamiya Tundra | roro72 | 1.9 Scale Rigs | 4 | 11-30-2010 05:31 AM |
Hardware for Tamiya Tundra...but not Tamiya? | twisted concept | Paint and Body | 1 | 03-28-2010 08:22 PM |
