Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya CR-01
Thread: Whats everyone runnig?
Old 03-10-2010, 09:51 PM   #1
Default Whats everyone runnig?
Just wanted to know what is everyone is running for motors, pinion gear, and tires on their CR-01?
Thanks.
teixeira1 is offline   Reply With Quote
Old 03-10-2010, 09:54 PM   #2
proline hammers with memory foam, RC4WD 35t motor and stock 20t pinion.
cydog510 is offline   Reply With Quote
Old 03-10-2010, 10:46 PM   #3
322
stock pinion integy 35 turn and depending on my mood either flat irons or mudslingers
322 is offline   Reply With Quote
Old 03-11-2010, 01:25 PM   #4
Tamiya 35T CR-Tuned motor, 21T Robinson Racing steel pinion
Vise Crawlers/stock foams/stock wheels w/Tamiya Star beadlock rings
or
for scale comps
Cliff Crawlers/stock foams/Proline 8-Shooters/ lead stick-on weights
860Crawler is offline   Reply With Quote
Old 03-11-2010, 04:58 PM   #5
constant:
10T HH Cobalt Puller, 21Tooth pinion, FXR, 3S 2000 maxamps, 645MG, TQ4 2.4ghz, RC4WD scale black shocks set-up in droop (no cantis and no barrel springs)
interchangeable (depending on mood)
tires:
Rok Lox (for daily/trail bashing and scale look)
cougars (for rock crawling...will buy the Nova foams soon)
M2Ks (for snow and water play...still looking for Red Rocks for snow)
wheels:
stock CR01 wheels, Mayhem double phatties, or Vanquish DHs
mtnhrdgr2 is offline   Reply With Quote
Old 03-19-2010, 02:05 AM   #6
Ez-run 32T brushless & 16T pinion, bit choppy at lowest speeds. Flat irons on proline Proline 8-Shooters.
vanDongen2 is offline   Reply With Quote
Old 03-19-2010, 10:53 AM   #7
27t w/ stock pinion on 3s with rock claws
benoj is offline   Reply With Quote
Old 03-19-2010, 06:09 PM   #8
Novak Goat 18.5 with a 13 tooth pinion.
wheels and tyres wise,
I used to run with Losi rock claws on proline 8 shooters alot, but have since gone to oversized tyres. Weight wise 12 oz on front 8 oz in rear.
Have got RC4WD X-locs with proline 2 stage memory foams, mounted on some DNA alloy sniper wheels, these tyres dont look much but they work for me. Weight wise, 16 oz in front 10 oz in rears.
Just recently got a set of Panther Leopards with proline 2 stage memory foams, mounted on another set of proline 8 shooters. Weight wise 16 oz in front 10 oz in rear. The weight needs re-addressing as the panthers are seriously grippy. But they are very impressive all the same.
igbandy is offline   Reply With Quote
Old 03-27-2010, 06:51 PM   #9
Here is my setup:
stock motor for now
Sidewinder ESC on 3s lipo
645mg steering servo.
Rock Claws with memory foam 16oz front and 8oz rear
Hammers with memory foam weighted same as above
Vise Crawlers with star cut foam weighted same as above
Which tires depend on where we are running at the time.
Rock Claws on granite.
Hammers or Flatirons on sandstone
Vise Crawlers for trail runs
It works well for me now.
I am surprised at how well my Unimog does against the Honcho. It looks top heavy but holds its own!!!!!!
dkur is offline   Reply With Quote
Old 03-29-2010, 01:09 PM   #10
HH 35t Handwound, 18t pinion. Currently thinking of going to a 16t pinion, and then adding a cell to my nimh packs.
As for tires/wheels, i run Rock Stompers on JConcepts for when im beatin around, and Rock Grabbers on 8 Shooters for when im crawlin or runnin in the snow. 6oz front in all front wheels, 4oz in the rear wheels.
low_range is offline   Reply With Quote
Old 04-20-2010, 08:09 PM   #11
hello guys....I am new in CR01
I just think to change the tooth pinion.
But, i saw u guys are using different size of the tooth pinion.
Here is what I am thinking now.
Less tooth pinion get more power?
Thanks
david_387 is offline   Reply With Quote
Old 04-20-2010, 09:27 PM   #12
David_387 less tooth does = more power, longer run time.
Here's what I'm running. 55t, 14t pinion, 2.2 chisel. My other has 45t, stock pinion and 2.2 stompers.
Old 04-21-2010, 01:30 AM   #13
thank you...
I am running Integy 55T Motor now,
so, is 14t pinion the way better than other #t pinion to fit on 55T motor?
Old 04-22-2010, 09:18 PM   #14
Mine runs really slow with the 14t pinion. It could use some more wheel speed. My other one uses a 45t and stock pinion, plenty of torque and wheel speed.
Old 04-25-2010, 03:25 AM   #15
Stock pinion, Novak & 55T, Stock Tamiya cliff crawlers and 30 year old NiCad batteries. WOOHOO!
rabfan is offline   Reply With Quote
Old 04-26-2010, 01:55 PM   #16
Novak 45T, stock pinion and 2.2 flat irons.
really happy with this combo, but I'm thinking about getting a 14T pinion and taller tires
Crawler-Mog is offline   Reply With Quote
Old 04-27-2010, 09:25 PM   #17
stock pinion 55T integy motor, Tekin fx-r, 11.1 v 1600 mAh battery
yxan is offline   Reply With Quote
Old 05-02-2010, 09:51 PM   #18
lt.
I'm running a 55T Racer's Edge motor that I got for $5.99
As for tires, I'm running 2.2 Flat Irons.
lt. is offline   Reply With Quote
Old 09-14-2010, 09:42 AM   #19
i was thinking bout dropping in my Novak 13.5T Brushless Crawler into a cr-01 with joker/lizard conversion... will it take the torque and speed? let me know before i do something stupid
K5krawler is offline   Reply With Quote
Old 09-14-2010, 10:55 PM   #20
stock pinion, Integy 35t and siped stock vice crawler tires
CJ318 is offline   Reply With Quote
