01-01-2011, 05:35 AM | #1 |
Pebble Pounder Join Date: Jan 2006 Location: outside reading, pa
| New axle housings?
Anyone have a source for new axle housings? I broke a shaft which pushed the C off the housing, which in turn ruined the two holes for the screws that hold the C on. All i could find was an aluminum housing from 3Racing (stellamodels, $53), and i swear i read some time ago that they dont work too well but ill be damned if i can find the thread anymore (anyone confirm this?). I couldnt find plastic replacement housings on tamiya's site (amongst others) which i find kind of odd. |
01-01-2011, 09:11 AM | #2 |
Rock Stacker Join Date: Mar 2009 Location: Denver
I've read mixed reviews about the aluminum ones. But is this the plastice one you're looking for? http://www3.towerhobbies.com/cgi-bin...?&I=LXUSH7&P=Z Good luck Giz |
01-01-2011, 09:31 AM | #3 |
Yeah thats it, but as you can see, Tower Hobbies has discontinued it.
01-01-2011, 09:37 AM | #4 |
I would just take down the parts information and shoot Tamiya an email. No way they don't have any of these left. Giz |
01-01-2011, 09:47 AM | #5 |
Maybe this is it? http://www.tamiyausa.com/product/ite...uct-id=9400723 Says "B" parts, and that's what the axles are. Dunno since there is no pic. Or you could just upgrade both and go different direction, http://www.junfac.com/shop/index.php...roducts_id=336 Good luck with your repair! Giz |
01-01-2011, 10:05 AM | #6 | |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
That is not the right part, the part number is 9005888 for the plastic case. Here it is: http://www.tamiyausa.com/product/ite...uct-id=9005888 | |
01-01-2011, 10:38 AM | #7 | |
Thanks Turtle. Hard to tell without pictures and lack of description. Have fun with your repair Low_Range! GIz | |
01-01-2011, 12:28 PM | #8 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
I dont know if this helps,but ive done the same,riping the screws out of the axles; What i did is drilled out the holes ,so the screws go through,dremmeled away the remains of the thread moulding inside the axle casing,and CA glued 3mm nuts inside the axle cases for the screws to screw into. Works well,and its a solid mount,instead of the soft plastic. |
01-01-2011, 03:50 PM | #9 |
Hey, thats a good idea. Considering its free, i think i will try that first Good find Turtle, if vipxj's trick doesnt work for me then i guess ill be getting in touch with Tamiya about getting some parts. Thanks all! |
01-02-2011, 11:01 AM | #10 |
Glad i could help.
