Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya CR-01
Thread: tamiya diff lock and shaft front or rear?
Old 03-22-2011, 08:02 PM   #1
Default tamiya diff lock and shaft front or rear?
any ideas? i could only afford one for the time being, does it reduce the slop in the diffs at all? front or rear? i am thinking of popping it in the rear, not really sure why though.....
any suggestions or theories are very welcome, i think nick (860crawler) has one in his.
cydog510 is offline   Reply With Quote
Old 03-23-2011, 07:31 PM   #2
No insight here. I will say any urge I've had to unlock my diffs has gone by the wayside within minutes of doing so. In my Creeper, I did the FLM thing and eliminated the diff gears with a big chunk of machined aluminum. Haven't had a problem in the CR01 though.
If you do put it in, I would be interested in your opinion of doing so.
DRW-FJ40 is offline   Reply With Quote
Old 03-25-2011, 11:51 PM   #3
I have it in the rear of mine and it gets rid of a lot of slop, I would recommend putting it in the rear as that is where most of the stress goes under acceleration.
AkFordfan is offline   Reply With Quote
Old 03-26-2011, 04:09 PM   #4
I didn't end up getting it. When the splines stirpped out on my rear axle I just got a new diff kit since it was immediately available. I still am definitely looking into getting it. Even though I haven't ever unlocked my axles, I still like the fact that I could if I wanted to, but these are tempting since it will potentially reduce that little bit of rollback inherent in well used axles
860Crawler is offline   Reply With Quote
Old 03-29-2011, 11:24 AM   #5
thanks AkFordfan
and yes, the roll back drives me crazy!
