03-29-2011, 03:02 AM | #1 |
Newbie Join Date: Nov 2010 Location: earth
| Skid Plate - axle A little showin' off my new skids I just made. I thought I'd give it it's own thread with a easy to find, searchable title. This section could use some more examples of this part. The last two are of the rear. The front skid I bent the right way with the protective film side of the aluminum sheet on the bottom side. The rear I did not and had to sand out some of the formation tramas. |
03-29-2011, 11:19 AM | #2 |
Quarry Creeper Join Date: Jan 2010 Location: vancouver, canada
great work, looks to be mocked from the junfac one. i like the rear one, but i am not sure it is necessary. good fabricating man. (on a side note i ordered from junfac, it didn't show up, no email or anything, so i had to pursue through paypal, not impressed)
03-30-2011, 12:18 AM | #3 |
| I may have subconciously ripped off the Junfac. As for dealing with Junfac, never gonna happen! I believe it's actually just an online vending machine, you send money - it send package unless, it's broke.
03-30-2011, 05:37 PM | #4 |
Newbie Join Date: Mar 2011 Location: Seattle
Wanna make me a set? I can't seem to find these anywhere.
03-31-2011, 01:56 AM | #5 |
regardless, it's good looking craftsmanship. now lets see if it can take a beating!
03-31-2011, 09:00 AM | #6 |
Rock Crawler Join Date: Mar 2010 Location: NRV
I've had the same experience with Junfac. I will never deal with them again. BTW, I've beat my CR so hard on rocks that I've ground the plastic down to the screws & they're are grinding away now. Some of them I will have to drill out if I need to take my axels apart so I think skid plate would be real helpful. |
04-01-2011, 06:49 PM | #7 | |
04-01-2011, 11:57 PM | #8 | |
| I couldn't find one either! Sorry, I'd make you one if we were in love but... it just takes me too long. Quote:
I really didn't want to give up the ground clearance for a "doo-dad" but, I was just starting to wear into the screws also. Crawling on bricks and broken jagged concrete was carving out more of my axle housings than I realized as well. It actually does have some benefits. The flat angled surface in front slides over surfaces better than the servo guard and tie rod. | |
04-02-2011, 02:04 PM | #9 |
04-02-2011, 10:34 PM | #10 |
Man, I'm sorry but I drew it on the aluminum. Just a note, if I did it over (front skid) I would probably make the very front slightly longer with a little more forward (downward) leaning angle to improve it's ability to slide over stuff. It does that well now, but I think it could be better. Something for the next guy to consider Last edited by jimjam; 04-02-2011 at 10:45 PM. |
05-12-2011, 08:03 PM | #11 |
Newbie Join Date: Nov 2010 Location: Canada
Nice work, wish I would have saw this when I built mine. I made a similar one but never thought to run the plate under the axle, not just in front.
