07-28-2011, 03:09 PM | #1 |
Quarry Creeper Join Date: Jul 2010 Location: PNW
| Super top heavy!
Is there a mod to where i can get my cro1 to not be so top heavy?
07-28-2011, 06:04 PM | #2 |
Quarry Creeper Join Date: Apr 2008 Location: PNW
Overall not too much you can do, I put a lipo in to reduce battery weight,put some weight in the wheels and chopped an HPI rubicon body to mount low to keep the rubber side down but it will be heavier on top than a lot of rigs are. I used to get frustrated with the tippy tendencies but now I like driving it more than my lcc because I have to use a different driving style and pick good lines. |
07-29-2011, 06:06 AM | #3 | |
Rock Crawler Join Date: Mar 2010 Location: NRV
07-29-2011, 12:39 PM | #4 | |
08-23-2011, 08:58 AM | #5 |
Newbie Join Date: Aug 2011 Location: Thailand
My CR-01's wheel. I'm not sure that is too heavy or not? |
08-23-2011, 09:24 AM | #6 |
Pebble Pounder Join Date: Apr 2011 Location: Cerritos
Like everyone said, strip the weight as much as you can up top and add more weight to the wheels to keep the cog low
08-23-2011, 01:29 PM | #7 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
i took all the cantilever stuff off mine and changed the shocks for some in semi droop. that took away a lot of the floppy mess. |
08-23-2011, 10:22 PM | #8 |
08-24-2011, 06:52 AM | #9 |
| I would have to dig around and see, that was a few years ago. I'm on my iPhone right now, if I get a chance to get to my main pc later I'll gladly hunt for that. For me it still kept the body too high and gave it that southern built mud truck look.
08-24-2011, 11:53 PM | #10 |
thought i had better pics of it, but i guess i was wrong. here is the thread with my old cr-01. if you look close you can see the shocks mounted to the chassis. lilburb, the trail beat blazer<---- clicky |
09-09-2011, 04:23 PM | #11 |
Newbie Join Date: Sep 2011 Location: Australia
ill post some pics tonight of what ive done to lower the cog. I lowered the chassis mounts and modified the suspension. Now its crawls better than ever pics coming soon.
09-10-2011, 09:27 AM | #12 |
Newbie Join Date: Dec 2010 Location: france
Before i decided to ditch the stock chassis from my Cr-01, i managed to lower the Cog a great deal while preserving the scale look. As a result it could stay on its side with a 5000 Mah lipo : I proceeded like this to obtain this result : - Lower the chassis rails on the chassis plates : Bear in mind that you'll probably have to trim the body to ensure your tires doesn't rub on it (it also depends on the diameter of the tyres you use, with those rockgrabber and the droop setup it was mandatory ...) - Attach the lipo to the front axle behind the servo with a velcro strap Here you can see i made 2 holes to the velcro strap that fit the 2 screws used to attach the front upper links, this way the velcro strap won't slip... I put a small rubber pad on the servo plate to ensure the lipo doesn't slip on it. I used a junfac servo plate for this mod, but you can easily make one to fit your needs. Attached this way, the battery is almost totally hidden by the chassis rails and you'll be surprised by your Cr01 rockcrawling capabilities. This was the last version of my rig with the stock chassis, and with full droop i could follow my friend's Gc3a, which i think is a good reference to give you and idea of the capabilities of the Cr01 stock chassis when correctly set up. Hope this helps... |
09-10-2011, 06:12 PM | #13 |
