12-02-2011, 10:58 AM | #1 |
Pebble Pounder Join Date: Jul 2011 Location: Belgium
| My rig
Shortened the wheelbase,lost the canti's,RC4 winch(need figuring out how to let it work with my DX3) |
12-02-2011, 11:47 AM | #2 |
Newbie Join Date: Nov 2011 Location: Vancouver
Looks good! Looks like you got some pretty awesome flex with your setup.
12-03-2011, 09:20 PM | #3 |
Quarry Creeper Join Date: Jan 2010 Location: vancouver, canada
the shortened wheelbase looks amazing with this body! good job.
12-03-2011, 11:47 PM | #4 |
Thanks, The biggest problem i had to overcome was that i had to shorten the rear driveshaft,and when the rearaxle went completely down,the driveshaft popped out. Got that problem solved now as well.Can't wait to test this thing!! |
12-04-2011, 12:02 AM | #5 |
Quarry Creeper Join Date: Jan 2011 Location: Australia
looks sweet as, you should drop the body right down, i have my slammed on the chassis, only a couple mm between the body and the chassis, its looks so much better and more scale with the shortened wheelbase, and you still keep all of your great performance
12-04-2011, 12:05 AM | #6 |
Do you have a pic of your FJ? I don't think i'm going to lower the body,because now the tyres don't touch the body |
12-05-2011, 02:36 AM | #7 |
yes i do, here are some pics for you: you can that there is almost no chassis poking out from under it, only about 20mm of the side chassis plates are visible hope this helps |
12-06-2011, 06:53 AM | #8 |
Rock Crawler Join Date: Mar 2010 Location: NRV
Nice looking truck! I love that color, what is it? you have two tasks that are on my list. shortening the wheel base on the FJ really makes it look so much better. I would imagine the turn radius improves as well.
12-06-2011, 10:47 AM | #9 |
Thanks DRW, The color is Tamiya copper,prrepare yourself to run into some trouble when shortening the wheelbase!!! I think have got it all sorted out now,going on a trail this sunday,i think that day will tell if everything is ok!! I have no idea if it a improves the radius,i haven't been able to drive it properly with longer WB! |
12-06-2011, 12:26 PM | #10 |
How much did you shorten the links? Did you have any other trouble besides the drive shaft length?
12-07-2011, 10:47 AM | #11 |
The links measure 50mm,without the ball ends. The only thing i had to do was remove the straight ball links from the upper mounts (chassis side)and replace them with bent ones from Axial Hope this helps! |
01-17-2012, 07:43 AM | #12 |
| Re: My rig
Changed a couple of things on my rig Mounted Stampede springs on my G-made shocks and dropped the body |
01-17-2012, 08:17 AM | #13 |
Pebble Pounder Join Date: Jan 2009 Location: South Africa,JHB
| Re: My rig
Good job, like the changes and the colour. Hope the Mrs doesnt mind you crawling on her stove top keep the updates coming |
01-17-2012, 09:32 AM | #14 |
| Re: My rig
Thanks,She wasn't home when i took the pics!!LOL I've been looking it over,what i would need for the shocks is the correct size springs,but softer ones. And work with a limiter in the shocks |
01-19-2012, 02:18 AM | #15 |
| Re: My rig
thats looks so much better with the body lowered, i am really loving the stance of your rig right now, maybe some really tall 1.9s would look sic on it?
01-19-2012, 01:40 PM | #16 |
| Re: My rig
I think 1.9's would look silly on there??
01-19-2012, 03:38 PM | #17 |
| Re: My rig
Not the Baka Claws from RC4WD, there the same height as the tyres you got on there now
01-19-2012, 06:47 PM | #18 |
Newbie Join Date: Jan 2012 Location: Australia/Melbourne
| Re: My rig
Second last pic... "Ka Chowwww..." looks just like Lightening McQueen's body language... Your cruiser is lookin very nice... The tyres scrub the guards when it's all twisted up though yeah..? Even more so when you turn the steer wheels I recon... -land cruiser 110... Are they 1.9's on your cruiser pic above..? Coz they look nice too... Not so far off set as the stock cr01 wheels... |
01-19-2012, 07:34 PM | #19 |
| Re: My rig
Those are CR-01 bealocks with 2.2 RC4WD Mud Slingers
01-19-2012, 08:32 PM | #20 |
| Re: My rig
I cant find those Baka claws you mention? The body rubs indeed,but very minimal |
