03-10-2015, 10:50 AM | #1 |
Newbie Join Date: Jun 2008 Location: Tucson, AZ
| Rear axle clocking for max 4WS tie rod clearance
I recently decided to upgrade to the 3Racing aluminum axle housings since I was really smashing my axles crawling around my backyard in Arizona (big rocks everywhere). I also picked up some KM Racing knuckles and hubs. The new parts went together nicely, but I'm a bit confused about the rear axle and how to clock the knuckles correctly. The instructions say to setup the rear axle with 25 degrees of caster and the fronts at 15. What I've found is that with the 4WS setup in the rear, my rear steer tie rod is making contact with gnar and getting chewed up and bent. A tie rod over knuckle would help, but I think I might just not have the axle clocked correctly. Does anyone have any photos of their rear steer setup to share? |
03-11-2015, 10:54 PM | #2 |
| Re: Rear axle clocking for max 4WS tie rod clearance
Alright, well I managed to get my rig back together properly and in order to obtain some additional (and much needed) clearance on the rear axle with 4WS, I performed a tie rod over knuckle conversion. This conversion is quite popular among fullsize crawler enthusiasts as a bent tie rod could result in a fully incapacitated rig in the bush. The procedure simply relocates the tie rod from the traditional attachment points below the knuckles to above them. On fullsize 4x4s, many times the drag link is attached to the tie rod for some reason... thankfully, with our CR01s that's not the case. Another popular mod for fullsize rigs is to get better drag link angles by attaching directly to the knuckle for proper crossover steering. In any case, here's the steps:
03-12-2015, 07:55 AM | #3 |
Interesting - I've never really given any thought to rear caster. I don't use 4WS generally, but I'm curious - do you have positive or negative caster on the rear? Looks slightly negative to my eyes.
03-12-2015, 10:19 AM | #4 |
| Re: Rear axle clocking for max 4WS tie rod clearance |
03-15-2015, 05:12 PM | #5 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
The rear axle has a natural positive caster due to the pinion angle. I have my chubs rotated forward to reduce the natural caster. Here's what mine looks like: The steering link sits a bit below the centerline of the axle, but it's close enough to the axle that it doesn't hang on rocks. From your pictures, it looks like you may have the knuckles reversed, because the arms for the steering links are sitting very low. Did you try flipping sides? Sent from my iPad using Tapatalk |
03-15-2015, 07:58 PM | #6 |
I tried every combination to find the best positioning. As I have it set now, the rear axle steering linkagehas much more clearance than the stock setup. I have, as I previously indicated, performed a tie rod over knuckle conversion. I'm running KM Racing hubs and knuckles, though... maybe that's where the difference is. |
03-15-2015, 08:17 PM | #7 |
That's probably the biggest difference. Looks like the arm on those knuckles is offset all the way to one end instead of roughly centered on the stock knuckles. That's probably intended to give more clearance for the steering link. If you were to swap them L to R, the steering link would probably be fine mounted under the arms. But if what you figured out works, might as well roll with it. Sent from my iPad using Tapatalk |
03-15-2015, 10:32 PM | #8 | |
| Re: Rear axle clocking for max 4WS tie rod clearance Quote:
03-16-2015, 08:15 AM | #9 |
There are 4 caster settings on the axle. If you move the A and B knuckles to the opposite side, you get slightly different caster angles. Didn't realize they worked this way. Working on steering on mine as well. I flipped the knuckles so the steering arm is on the bottom, and mounted the steering links on top of it (exactly as you did in the rear) - was still too high, so I swapped C's. Much better. Love tinkering with these rigs - so many adjustments you can mess with. |
Rear axle clocking for max 4WS tie rod clearance - Similar Threads | ||||
Ackerman VP steering tie rod for more clearance? | redsawacs | Axial AX-10 Scorpion | 4 | 01-29-2014 09:12 PM |
Rear Axle Clocking... | cboggs | EnRoute Berg | 3 | 05-31-2010 11:29 PM |
clocking the rear axle | Redfinger | EnRoute Berg | 6 | 02-05-2010 10:48 AM |
KK high clearance tie-rod vs. CKRC OTA tie-rod vs. ?? | BigB_117 | EnRoute Berg | 64 | 07-06-2009 11:20 PM |
