Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: need set up procedure for touareg esc.., help a brotha out.
Old 05-26-2005, 10:44 PM   #1
Default need set up procedure for touareg esc.., help a brotha out.
ok im using the stock esc that came with the touareg along with xxl fm receiverw/ a xr-3 remote... and I cant seem to get it to set.
86ss1 is offline   Reply With Quote
Old 05-26-2005, 11:26 PM   #2
2006 2.2 National Champ
BENDER's Avatar
I just went through this. You have to plug the red BEC plug from ESC into the BEC input on reciever, otherwise it you won't be able to program it.
Are your servos working at all right now?
BENDER is offline   Reply With Quote
Old 05-27-2005, 07:19 AM   #3
nope.. I turn on the esc and it just starts beeping....
Old 05-27-2005, 07:28 AM   #4
ok.plugged it in and I am getting servo action and forwward,..But I have no reverse.
also.How do I know when I am full throttle. I have the led on solid until I go full throttle and then it turns off.. Is that right??
Thanks for your help...by the way..
Old 05-27-2005, 09:35 AM   #5
Diggin' the new SCX10 II!
badger's Avatar
You know your at full throttle when that thing is hauling ass down the freeway!
badger is offline   Reply With Quote
Old 05-27-2005, 10:53 AM   #6
rbgerrish's Avatar
Did your Touareg not come with ESC setup instructions?
rbgerrish is offline   Reply With Quote
Old 05-27-2005, 12:19 PM   #7
yeah but I dunno how to read.....
j/p ... I lost lost them somewhere....
Old 05-27-2005, 11:13 PM   #8
Step 2: Turn on receiver. When installing for the first time, LED light will flash once.
Step 3: Push set button once with throttle trigger in neutral. (push set button for more than 0.5 sec. LED flashes.)
Step 4: Pull trigger to maximum acceleration and push set button once. (LED changes to a double flash)
Step 5: Push throttle trigger to maximum reversing and push set button once. (LED turns off)
That's straight from the manual, hope that helps.
David
Davkin is offline   Reply With Quote
Old 05-28-2005, 02:44 AM   #9
Davkin - It worked perfectly...Thank you so much....
