01-23-2008, 07:42 AM | #1 |
Rock Stacker Join Date: Feb 2006 Location: Sugarland, TX
| axial diff in a stealth trans
anyone tried it yet and if so does it fit? the trannys look almost the same.
01-23-2008, 08:15 AM | #2 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
The bearings are the same size(od) as is the gear, the problem is the shoulder on the axial hub( were the bearing rests) is to wide and will not allow the t-3 trans to close properly. If you have a lathe you could easily make it fit. or............. 62pyro seels diff lockers for that tranny. |
