05-30-2005, 09:28 PM | #1 |
Newbie Join Date: Jul 2004 Location: middletown
| newbie tlt 10 build up w/*new pics*
yep i caught the bug so i started the tlt two days ago. finished the axles and pede tranny install yesterday, got the t-maxx links and servos on it today. took some picz of what i have so far, let me know what you think. thanks race4fn http://www.rcpics.net/view_single.php?medid=58031 http://www.rcpics.net/view_single.php?medid=58030 http://www.rcpics.net/view_single.php?medid=58028 http://www.rcpics.net/view_single.php?medid=58027 Last edited by race4fn; 06-02-2005 at 10:33 PM. Reason: maybe these pics will friggin work |
05-30-2005, 09:32 PM | #2 |
| tlt 10
forgot to ask where is a good way to mount the shocks on axles and do you run them straight up or at an angle? and why? thanks race4fn |
05-30-2005, 09:36 PM | #3 |
RCC Addict Join Date: Feb 2005 Location: Crawlifornia Uber Alles
if you lay the shocks down, you will get more travel at the wheel.
06-02-2005, 10:32 PM | #4 |
| more pics
wheels and tires and the shocks are now on enjoy http://www.rcpics.net/view_single.php?medid=58361 http://www.rcpics.net/view_single.php?medid=58360 http://www.rcpics.net/view_single.php?medid=58359 |
06-02-2005, 10:39 PM | #5 |
if you feel like experimenting, try laying down your shocks even more. maybe move the upper mount another inch towards the middle. i think you will be surprised with the increase in suspension travel.
06-02-2005, 10:47 PM | #6 |
| shocks
ill try that but the farther you lay them down the stiffer the spring rate becomes i beleive.
06-02-2005, 10:51 PM | #7 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Nice rig BTW. | |
06-02-2005, 10:52 PM | #8 | |
Quarry Creeper Join Date: Jun 2004 Location: Ventura
06-02-2005, 11:07 PM | #9 |
| layed down shocks
yea i had it backwards you want to avoid that in 1/10 truck racing cause it makes em bottem out real bad, but wouldnt that be a bad thing to loose spring rate as you get close to full articulation wouldnt it make you loose traction as oppiset tire unloads from truck rebounding.
06-03-2005, 08:07 AM | #10 |
think about it this way, if everyone is doing it, it can't be all that bad and wrong
06-03-2005, 10:08 AM | #11 |
| shocks
layed the shocks down another inch and its binding up real bad you can see in the pics how the fronts are where they were and the rears are layed down maybe iam missing something let me know if you see what tnx race4fn http://www.rcpics.net/view_single.php?medid=58399 http://www.rcpics.net/view_single.php?medid=58398 http://www.rcpics.net/view_single.php?medid=58397 http://www.rcpics.net/view_single.php?medid=58396 |
06-03-2005, 12:27 PM | #12 |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
flip the shock around so the shaft end is at the axle, and the body is by the chassis.
06-03-2005, 01:10 PM | #13 | |
Quarry Creeper Join Date: Sep 2004 Location: On my acre and a half of Gods Country. Prosper, TX
06-03-2005, 01:44 PM | #14 |
give 'em a flip. the angle looks good though.
06-03-2005, 04:08 PM | #15 |
Newbie Join Date: May 2005 Location: upstate
Can you post pics of how you got the pede tranny into the stock chassis?
06-03-2005, 06:19 PM | #16 |
Rock Crawler Join Date: Nov 2004 Location: Thats a Good question
Looks good, hope it works well.
06-03-2005, 08:58 PM | #17 | |
06-03-2005, 09:01 PM | #18 | |
06-04-2005, 10:59 AM | #19 | |
| chassis cut out Quote:
you can see here how i cut the chassis out for the fitment of the tranny theres a big hole to fit this side in also you can see how i had to move the links all the way out to clear the sliders http://www.rcpics.net/view_single.php?medid=58466 here you just widen out the hole but you can see all the holes i had to drill because its so close you have to really be creative to make everything clear. its not easy but iam only using the stock chassis to make everything work then iam gonna cut a new chassis out of carbon fiber. hope this helps. also you have to flip the links to make everything clear the uppers that are mounted inside chassis plates need to be on bottum to fit. Last edited by race4fn; 06-04-2005 at 11:02 AM. Reason: forgot stuff | |
06-05-2005, 08:12 AM | #20 |
RCCRAWLER TEAM DRIVER Join Date: Jun 2005 Location: Voiding warranties
You can try using a long screw and use the same mount as the upper link on the outside and that will get the shock above the link and maybe cure the bind. It will also move the shock foward and give you more laydown in turn. |
