01-30-2008, 09:12 PM | #1 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
| Inner C-clips
So I have searched and not really found an answer. So I have to pop my front apart before this weekends comp and I am still running the treeclimber shafts--Now I have not broken one of them(went thru the smaller stockers) YET--and will be upgradding the front shafts next month. So I heard a rumor I can remove the inner c-clips so if I pop a front shaft I can just slide them out--is this true or is there something else I need to do? Thanks for any input |
01-30-2008, 09:19 PM | #2 |
Rock Crawler Join Date: Feb 2007 Location: wahiawa
if you are talking about the axle shafts you can run um with out the e clips the knuckle hold it all in place..thats how Im running my truck now...just cause you have a time limit to work in your truck I aint about to strip my truck just to change the axle...hope that helps |
01-30-2008, 09:24 PM | #3 | |
Yup--those clips. I have alum c's so its harder to get the front axle apart | |
01-30-2008, 09:28 PM | #4 | |
Quarry Creeper Join Date: Oct 2005 Location: SoCal
saves lots of time changing axle shafts thats for sure. when your tired of breaking axles get some CVD's | |
01-30-2008, 09:30 PM | #5 |
01-30-2008, 09:55 PM | #6 |
01-30-2008, 10:32 PM | #7 |
01-30-2008, 10:39 PM | #8 |
Quarry Creeper Join Date: Jan 2006 Location: Ukiah, CA. (nor cal)
yea the search dos'nt come up with too much. try " quick change axle " or something like that . anyway I'm not running the inner clips so all I have to do is pop off a knuckle and pull the axle. I also shimmed my axles while I was pulling the clips (changing a broken axle). so to answer your question yea you don't have to run the clips...
01-30-2008, 11:18 PM | #9 |
| inside the cup on this part http://www.rcpcrawlers.com/product.p...&cat=17&page=2 |
02-01-2008, 02:52 AM | #10 |
Rock Crawler Join Date: Aug 2004 Location: Saugus
Sure does help with how often half shafts break.
