06-05-2005, 03:46 AM | #1 |
| new chassis: lower cog, higher clearance
here's the idea: lay down the E-Maxx tranny on a pan, with the battery and electronics on the right side. the left-hand plate will be a bit of a jigsaw puzzle, but this shot gives you the general idea. the wheelbase has also been stretched considerably, out to 12-1/2 at least in this proto stage. the motor's 1/2 inch lower, the center clearance is 1/2 inch higher, shaft angles are a bit more friendly. should be a big improvement once it's done. |
06-05-2005, 07:34 AM | #2 |
RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
| Keep us updated. I'd like to see more pics as it comes along. |
06-05-2005, 05:37 PM | #3 |
06-06-2005, 06:30 PM | #4 |
06-07-2005, 08:44 PM | #5 |
more pics: that's a Pede tire underneath. the red cable operates the shifter. an overhead shot gives you the general layout. with the wide chassis and 14"wb i'll have to use a 1/8 scale body. i've got an F-150 quadcab at the LHS that i'll pick up this weekend. mandatory artic shot. this chassis is a huge improvement over the TLT plates, although the longer wb means the breakover anlge remains the same as before. methinks a set of Masher 2000s is next on the list. |
06-08-2005, 12:32 PM | #6 |
so now i have to wonder, with a 14" wb and more E-Maxx parts than TLT (i'm down to just the waxles now) is it still a TLT crawler? or a Maxx-based crawler? or just another mutant?
06-08-2005, 02:30 PM | #7 |
Quarry Creeper Join Date: May 2005 Location: Auburn
dunno all thats left on mine that it tamiya are the axles and link ends ( soon to change, that)
06-09-2005, 08:53 AM | #8 |
| threw an old body on, cut the hell out of it, and crawled. i didn't have the heart to cut up the flamed Bronco but this one, who cares. Last edited by microgoat; 06-09-2005 at 08:54 AM. Reason: wrong pic-wtf? |
06-10-2005, 05:57 PM | #9 |
Rock Stacker Join Date: Jun 2005 Location: Indian's Cupboard
How did you do your body Mounts? Thanks alot, Cya |
06-11-2005, 04:53 AM | #10 |
body mounts were easy. when i cut the side plates they were taped together to assure micro-precision symmetry. i drilled 2 holes for each shock mount, not knowing which one would work. the ones that didn't work became body mounts. just use a post-type mount screwed in from behind (is that term gonna make Digler excited?)
06-17-2005, 12:33 PM | #11 |
Newbie Join Date: Jun 2005 Location: san ho
who makes that bronco body / i need it so i can match my crawler with my real bronco
06-17-2005, 12:38 PM | #12 |
bendforthebone Join Date: Feb 2004 Location: Jamul
its made by parma. here http://www.parmapse.com/rcitem.asp?n=10260 and http://www2.towerhobbies.com/cgi-bin...?&I=LXDA52&P=7 By the way whats your sn on FSB? |
06-17-2005, 05:52 PM | #13 |
it's a good enough body, but the grille/headlight stickers look like they were drawn by a crack baby. prepare yourself for a lot of hand-painting if you want it to look like anything.
06-17-2005, 06:43 PM | #14 |
i really like your setup. its totally new to me. looks like a clean and solid build.
06-19-2005, 06:17 AM | #15 |
| goin' 60/40 |
06-19-2005, 03:54 PM | #16 |
man, we have salvages here too! those hicks
