06-05-2005, 02:54 PM | #1 |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
| little help please?
ok, i was digging through my closet and found a body i want to use for a scale crawler....... the body is 7 1/4 inches wide and i dont want the tires sticking out more than an inch on each side..... what axles could i use? i want to use Imex Claw Dawg tires because they are 4 inches tal and i think this would look perfect on 4 inch tall tires........ would TLT axles with stampede wheels and the claw dawgs be 9 1/4 inches wide? i guess i could always narrow the tires and wheels some....... |
06-05-2005, 03:44 PM | #2 |
RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
| TLT axles should work for you as long as you pick the right wheel and tire combo to keep it as close to 9 1/4". I currently have HPI Split 5 wheels and Proline Masher 2000 on mine. And without the wheel wideners mine measures 9 1/2". That should be similar to the Claw Dawg. Masher 2000's are just less than an inch taller. I've never tried Stampede wheels, but I think they have a larger offset than the HPI ones I am using. |
06-05-2005, 03:45 PM | #3 | |
Pebble Pounder Join Date: Mar 2005 Location: Utah
David | |
06-05-2005, 04:37 PM | #4 |
Newbie Join Date: Jun 2005 Location: Alpharetta
the front wheels and rear of the stampede are different. the rear ones offset go in deeper so its not wider and the fronts are pretty close to your HPI 5 spoke Starz.
