Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Torque steer
Old 07-18-2004, 08:42 PM   #1
Default Torque steer
have my tlt-10 95% done but i have a ton of torque steer. I know with out pics ( will have them soon ) it'll be hard to say but what can be done to limit this
Nish is offline   Reply With Quote
Old 07-19-2004, 04:51 PM   #2
Default Re: Torque steer
Thicker oil/stiffer springs would help it.
Mine doesn't torque steer at all
CustomCrawler is offline   Reply With Quote
Old 07-19-2004, 06:00 PM   #3
won't stiffer spring make the movement too stiff for this size ride?
i am using maxx shocks with stock oil & springs. they are mounted to the axles & cantilever hole should i move the chassis placement?
Old 07-19-2004, 11:51 PM   #4
I'd say stiffer springs, or atleast preload more on that side. If you move the shocks to a further out hole, you might limit suspension travel, but you should also counteract the torque roll more because the shocks at more of a perpendicular angle, giving them greater efficiency.
Plays_with_Toys is offline   Reply With Quote
Old 07-20-2004, 06:54 AM   #5
I run the same shocks with the same springs mounted in almost the same posistion. But I use 35wt oil so that might help. Is your TLT extended or stock length
Old 07-20-2004, 03:32 PM   #6
extended withe the maxx links. i'm gonna try to get pics up soon
