06-11-2005, 06:20 PM | #1 |
Rock Stacker Join Date: Jun 2005 Location: Indian's Cupboard
| Stampede Sliders and output shaft...
How do i get axles onto the output shaft onto the axle? I cut off the lip and searched the forum several times. When ever i drive it just pops off.... :( Thanks, CYa |
06-11-2005, 06:25 PM | #2 |
RCC Addict Join Date: Dec 2004 Location: Central NY
just put it on as far as possible and tighten the grub screws as tight as possible.
06-11-2005, 06:26 PM | #3 |
That would be nice... Ive tried that several hundred times.. Thanks though.
06-11-2005, 06:29 PM | #4 |
glue them on then or drill a hole through the little thing on the axle that you put the yoke on so you can use the really long screw thing to go all the way through
06-11-2005, 07:14 PM | #5 |
Pebble Pounder Join Date: Apr 2005 Location: Torrance, CA
Don't forget to loctite the allen screws. That's important.
06-11-2005, 09:07 PM | #6 | |
You are running the stainless steel yokes right? If not then that is part of your problem. Get the stainless steel yokes and all will be good again. Or drill the diff pinion so you can run Maxx sliders. | |
06-13-2005, 06:29 PM | #7 |
Rock Stacker Join Date: Jan 2005 Location: Sutton Motorsports Headquarters
Try some output shafts from the traxxas villan electric boat. They look like the white nylon stampedes but have a metal collar where the grub goes. You will have to drill them out to fit and also loc-tite the grub.
