06-12-2005, 05:11 PM | #1 |
RCC Addict Join Date: Apr 2004 Location: Santa Clara
| SlinkySam's first crawler
Well, I have been around RCC.com for a while and itchin to build one. I have seen some of the best crawlers that the Nor-Cal group put together and just couldn't resist diving in. I wanted to build a scale Slinky, but pushed that off until I learned more with the TLT axles, tube creation and more. Here is my first project, which took a really long time to come to life. I only got to put in 10 minutes here and there, but eventually got something running. Last night was my first 4 wheel drive run and it was fun to see it come alive. Here is what I run. Nothing special in any way compared to the crawlers out there now.
It isn't finished of course (they never are), but I couldn't resist plugging it all in and running. Things are zip tied and taped in place just for a fun run. It was awesome. I think I can keep the Slinky name going as I rolled more times in this rig in the first few minutes than I have all my 1:1 rolls combined. I have rookie fingers. Despite it being heavier than most with the Bruiser tranny and motor, it still was decently stable. It bottoms out a little early, but it works fine. Also, for how flexible and soft it is, it really has no torque roll at all. Nada. I was shocked to see nothing. However, here is a problem that I just found which maybe someone can decipher. It was running fine last night and today. Mid way through the day today, I started a climb and it stopped moving forward or back. Pushing the throttle, there was nothing. Not even a buzz. I figured I fried something or ran out of juice. That wasn't the case though because I gave it a little nudge and it worked again for a short distance. It appears as though there may be a stall spot on the motor. A particular point where it won't turn in either direction. A burn in the windings/brushes perhaps? Any thoughts on what to look for? Anyway, here are some pics on the rocks during testing. Not much to look at, but it works finally. -Sam Last edited by SlinkySam; 06-12-2005 at 05:16 PM. |
06-12-2005, 06:10 PM | #2 |
Moderator Join Date: Apr 2004 Location: In my head
Good looking crawler!
06-12-2005, 06:14 PM | #3 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
Agreed. Any plans for body panels or more tube?
06-12-2005, 06:17 PM | #4 |
Pebble Pounder Join Date: Aug 2004 Location: California
It might be brushes, If the motor is old and has been used you might want to replace the brushes. But if it is a new motor that shouldnt be the problem. If the motor is new make sure your brushes are not hung, just pull them out and let the spring snap the brushes back in the motor. Hope this help And your truck is SWEET!!! |
06-12-2005, 06:24 PM | #5 |
Thanks for the kind responses. It is a WIP (work in progress) at the moment, so a few more touches are in order. I am testing cardboard cutouts of body panels (the final ones will be lexan) right now for the right look that I want. Here is one panel I was making. I also need to make a hood for it also. It'll definitely clean up and look better with paint, skins, maybe spreader tubes on the front shield area and more. Thanks for the motor suggestion. I will tear it apart to see if that is it and clean it in the process. Maybe while I have it apart, I can re-wind the motor for more torque. I saw a great article on it in the Electronics section. -Sam |
06-12-2005, 06:29 PM | #6 |
RCC Addict Join Date: Dec 2004 Location: Central NY
lookin good. i like the panel.
06-12-2005, 07:28 PM | #7 |
Rock Stacker Join Date: May 2005 Location: castlerock
Bad *** man. I like it. |
06-12-2005, 07:52 PM | #8 |
Pebble Pounder Join Date: Mar 2005 Location: in tha lab ( the shop )
cool if u eva need powder coating hit me up i bet it would look hott in the black tube and dark flake blue
06-12-2005, 08:21 PM | #9 |
RCC Addict Join Date: Feb 2005 Location: Crawlifornia Uber Alles
i have a pair of new complete TLT axles, and this inspires me to build a tube chassis.
06-12-2005, 08:46 PM | #10 |
Oooooookay......... I don't think I should have pulled the motor apart..... hahahaha :-P I tend to just jump into things blindly and this was one of them I bet. I don't think this motor was serviceable, but I serviced it. I am in the middle of putting it back together. Unfortunately, to pull it apart, tabs had to be bent and I sort of "tweaked" the back endbell plate in the process. I cleaned it out, though it seemed ok, to me anyways. The brushes looked clean, but maybe had some damage. Not sure. I can't replace them anyway since they aren't removeable. Oh well. Back together it went. It's sort of not going back together now due to the tweaks and bends. It seems to be binding a bit. Also, I have no way of clamping the back panel back on again, so the soldering iron is coming out . I will let you know how it goes, but I don't think it will work again. I guess I am in the market for a new motor... haha The powder coating sounds good. Have any examples of what you have done before? Do you work at a powder coating place? -Sam |
06-12-2005, 09:14 PM | #11 |
Quarry Creeper Join Date: Oct 2004 Location: vegas
What connectors are you running off of your esc to battery? If it is tamiya plugs then that may be the case. Look in it where the battery goes. The little metal things may be bent out of place, which will not hit hte battery = loss of power. Switch em out with Deans. |
06-12-2005, 09:38 PM | #12 |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Nice little crawler you have there Sam. Jay |
06-12-2005, 09:58 PM | #13 |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
Nice looking rig you got there. Are those the EDC progressive piggy backs? If so, how are yours holding up? Mine leak like a (something bad). The company is pretty good to deal with (mine were missing some pieces and they sent out replacements for free), but those little o-rings are so weak. I am thinking of just taking the piggy backs off and mounting them to my hotbodies shocks instead. |
06-12-2005, 11:58 PM | #14 |
Thanks again for the comments guys. It's embarrassing how long it took to get this far, but hey, its working. Plays_with_Toys - I don't believe they are the EDC shocks based on how you described yours. The reservoirs are part of the main shock housing and not removeable. I was actually going to hook up hydraulic lines out the end of them and interlink the shocks to provide a forced articulation set up, but I didn't want to destroy them right away. I got them from RCKJeep a while back. sean_lv_crawler - I swapped out all the stock connectors for Deans connectors. They are all solid soldered connections so that doesn't seem to be the problem. I tore the motor down and put it back together. No luck there in cleaning it up. However, in the meantime, I hit the switch so that the ESC would run off the servo battery pack instead of the motor battery pack. It all works again with the swap on the power source, but just not sure why it stopped working. -Sam |
06-13-2005, 05:21 PM | #15 |
Quarry Creeper Join Date: May 2005 Location: Ontario, Canada
Hey, thats a sweet crawler... looks great...
06-13-2005, 06:35 PM | #16 |
RCC Addict Join Date: Jun 2004 Location: Bruiser Heaven!!!!
nice looking crawler
06-13-2005, 07:46 PM | #17 |
the motor comm is probably dirty and needs a cut. does it look dirty, black, and glazed? that is a dead ringer for stalling that will end with a nudge. thats a really slick crawler. makes me want to resurrect the old tlt axles too! |
06-13-2005, 08:14 PM | #18 |
we own the oven and the spray gun and madd powder yeah ill get pics up asap
06-13-2005, 09:49 PM | #19 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Guys the 750 out of a bruiser is basically a standerd closed can mabuchi (simmiler to what tamiya kits have) only mucho bigger. So there really isnt a way to cut the comm or change the brushes. So your really kinda stuck-I would look for a new one on ebay (they're fairly cheap) or if that doesnt work you can buy a GSpeed 700 (non BB) which is a faster and more powerfull motor. http://www.hobby-lobby.com/speed700.htm Found there for $28 Like I said though-resist the urge to get the ball bearing version as it doesn't fit the bruiser case! |
06-13-2005, 11:10 PM | #20 |
OK I am so hooked on RC Crawling it is disgusting. I just went through 2 more packs tonight since I got home. I need to fix it already due to abuse and use. I can see this is going to be an expensive hobby to maintain at this rate. Thanks for the input guys. So as I stated and Highmark clearly clarified, these motors definitely aren't maintainable (well by my abilities). It was glazed quite possibly and did have some blackened areas. Then again, it looked like most used motors I have seen, so that may be it. It is working again though. Despite not supposed to being able to tear the motors apart, I got this one apart and back together again and have been running it ok. I did have to solder the end bell plate back on since the lock tabs were a little...um... mangled. So back to the rocks and back to flipping I went. It's time to go in and tighten everything up again. I am starting to get slop on some of the drive interconnects. Highmark - The 700 motor you pointed out, how comparable is it to the stock 750? One thing that I notice is that since I run the motor backwards in the chassis, it doesn't drive the same. I assume there is something with how the motor is built that it performs better in one direction than other. I will have to read more about how these motors are built. Ok, enough chit chat, time to go take the battery off the charger I am ready to hook up with some others and do a trail ride. -Sam |
