06-14-2005, 08:25 PM | #1 |
Rock Crawler Join Date: Nov 2004 Location: Thats a Good question
| Very stupid question.
not that i am new to this but what is the easiest way to drill a tlt axle output shaft, i used pede liders without drilling and they worked, but now i would like to go with maxx sliders so i need to drill, thanks.
06-14-2005, 08:34 PM | #2 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
Do you know someone with a drill press?
06-14-2005, 08:46 PM | #3 |
Pebble Pounder Join Date: May 2004 Location: east coast
i just got a small dremil bit i dont know the size and just started drilling into the center of the tab that comes out of the axle and it fit just put it on a flat surface then drill it out matt |
06-14-2005, 09:06 PM | #4 |
i dont have a drill press, if i had a punch to set the bit i could just drill. i will try that,
06-14-2005, 09:11 PM | #5 |
I just used a simple drill and a vise. Took about 15 seconds per hole. I made them a bit smaller than the diameter of the Maxx set screw/pin so I wouldn't have to remove as much material off the shaft. I then shaved down the pin/set screw to fit the smaller hole. I have never had one come loose and I've been running it since November of last year. |
06-15-2005, 01:59 AM | #6 |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
When I did mine I set the tire in a vice (since my diffs are locked) which held the pinion in place. Then set the drill bit in, and set the drill the opposite way you want to go, and work a little divit. Then put it in the right direction and drill the hole. Took me maybe 5 minutes per axle.
06-15-2005, 09:41 AM | #7 |
thanks for the replys, i found my metal punch to put a divit, worked great, i had to get my neighbor to hit the punch because i only have two hands and no vise.
