06-15-2005, 01:57 PM | #1 |
I joined the Band! Join Date: May 2005 Location: taos
| Do I Run Foam In My Tiers Or Not ?
hallo im building a tlt crawler i got in my tires today thay are masher 2000 and chrome stampede wheels i am going to do some prety hevy duty rock crawlin but my ? is do i run um with or without foam ? thanks Avery Austin. |
06-15-2005, 04:06 PM | #2 |
Rock Stacker Join Date: May 2005 Location: Ewa beach
you don't need the foam in the tires it will work good without it, or you can cut half of the foam off so it is a small donut that works good too
06-15-2005, 04:45 PM | #3 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
Most people including me run no foams in their Masher's.
06-15-2005, 05:16 PM | #4 |
Rock Stacker Join Date: Jan 2005 Location: West Texas
what about all-t's?
06-15-2005, 06:01 PM | #5 |
Rock Stacker Join Date: May 2004 Location: Austintown
no foam with about 4, 3/16" holes in the rim
06-15-2005, 06:22 PM | #6 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
Well It really depends on the weight of your rig. Yes most people don't run foams in 2.2 scale rigs. But I had to run them in Ralph because it was a couple of pound chassis. So before you glue the tires it's best to do some testing. I ran ALL-T's on Ralph with foams. I just used some 2.2 Losi racing foams cut in half. Wheels ran full foams and he won a comp with that set up and it wasn't a heavy rig either. So, DO YOUR OWN TESTING!!! see what works for you.
06-15-2005, 08:13 PM | #7 |
Pebble Pounder Join Date: Dec 2004 Location: Medina, Ohio
can you drill holes in the foam to change the presure? has anyone tried it?
06-15-2005, 09:05 PM | #8 |
i have herd about guys doing that it sounds like a good idea.has any body tried this ?
06-16-2005, 11:44 AM | #9 |
Quarry Creeper Join Date: Mar 2004 Location: Central NY
I don't think drilling holes in foams would have as good an effect as cutting chunks out of them. Drilling holes vs cutting chunks would be like cutting the foam's diameter in half and using the outer portion vs the inner portion. In using the outer portion there's more flex than stock (drilling holes) but it's still providing support for the tire. In using the inner portion (cutting chunks) there's even more flex but no tire support; not a bad thing for pure crawling. For my Goliath, since I planned on it being a basher/crawler, when I cut my foams I used the outer portion in the rear tires and the inner portion in the front tires. But for pure crawling with tires that have tall sidewalls and especially those with no side-biters, the idea is to have a small portion of foam around the wheel so the tire can flex a lot, but not over-flex and catch on the wheel. I'd say go with that route if using foams at all, unless your rig is heavy, in which case cut carefully and you can experiment like Rckjeep mentioned. |
06-16-2005, 01:39 PM | #10 |
Quarry Creeper Join Date: May 2005 Location: Ontario, Canada
hey, should foams be used in 2.2 swamp dogs ? :?
06-16-2005, 01:46 PM | #11 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
