06-19-2005, 06:54 PM | #1 |
RCC Addict Join Date: Feb 2005 Location: Crawlifornia Uber Alles
| New(to me)Tuber pics & questions for the bruiser guys
new addition to my small scale family. john boyer chassis/TXT tranny/bruiser axles. i got it from rockpiledriver, and assured him it was going to a good home! bruiser guys- i need a right front inner axle shaft to replace the broken one. if any of you have a spare, please pm me. also, are there spacers/adapters that will make the front axle width the same as the rear? what about adapters to run different wheels? thanks in advance for the help! hope you dig the pics! |
06-19-2005, 06:58 PM | #2 |
Pebble Pounder Join Date: Mar 2005 Location: in tha lab ( the shop )
thats soooo hott man but that carbon siding looks like an open airbrush canvas for me i do airbrushing so pm me my french friend can hook it up
06-19-2005, 06:59 PM | #3 |
Pebble Pounder Join Date: Jun 2005 Location: boston
you can buy hubs that are locked that have a standard hex, i might have axle, do you need stub shafts, or the inside shaft with ring gear on it? rc4wd might have adapters for the wheels, i forgot where i got mine, also bruiserbuilder.com forest there has alot of parts.
06-19-2005, 07:05 PM | #4 |
i'm pretty sure i need the inside shaft with the ring gear. i'll have to take it apart and check it out. my first bruiser.
06-19-2005, 07:14 PM | #5 |
Rock Crawler Join Date: Dec 2004 Location: Grand Forks, ND
i would do like aguilar3 (i think that is who did it) did on clodtalk. he used two front axles and had 4ws. this would solve your width problems.
06-19-2005, 07:41 PM | #6 |
lmk, i have a complete front axle without knuckles and stub shafts,(just housing bearings and inner shaft)
06-19-2005, 11:04 PM | #7 |
Pebble Pounder Join Date: Jan 2005 Location: Pocos Pero Locos....SoCal
Yeah,That was me I used 2 frt cases for 4wheels steer and also added a set of Delrin wideners since the frt cases are much narrower then the rear cases Delrin spacers Before after on this Hilux/Bruiser Hybrid,I also added delrin widener/spacers to even out the frt cases with the rears |
06-19-2005, 11:08 PM | #8 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Gregrocks... Nice tuber, but the links (and driveline) seem a bit steep. I see that the rear axle is rotated so the pinion is up. Bring'm down some...it'll lower your CG as well. |
06-19-2005, 11:09 PM | #9 |
BTW,loose the side plates and and youll have a kickash Bruiser. They just dont look right. also, that upper link mount is very trick...can I get a closer pic? |
06-20-2005, 02:57 PM | #10 |
thanks for the suggestions, guys! i might ditch the bruiser axle set-up and use TLT axles instead. still thinking about it. super sancho, i'll post some close up pics of the upper link mounts later today. |
06-20-2005, 04:06 PM | #11 |
Quarry Creeper Join Date: Jan 2005 Location: Crafty mexicans and your glass candy...
mmmmmmm.... bruiser
06-20-2005, 08:21 PM | #12 |
super sancho. here are the pics of the upper link mount. hotrodcj, here is a photo of the broken axle. if you just want to sell the axle shaft, pm me. |
06-21-2005, 12:02 PM | #13 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
What broke? Did the pin fall out of the one end? Or is the other end sheared off? I never took it apart |
06-21-2005, 12:28 PM | #14 |
the ball where the pin goes in sheared off. should be able to find one with some searching.
06-22-2005, 12:39 AM | #15 |
You can get the axle for around 10-15 bones on ebay...Ive bought a few NIB units for $25 myself btw,The servo mount and link mounts are pretty sweet looking...took me forever to figure out what I wanted to do with my setup ... |
06-22-2005, 01:17 AM | #16 | |
Quarry Creeper Join Date: May 2005 Location: lost in vintage tamiya land.
06-22-2005, 08:19 AM | #17 |
yep, that's a great looking truck! problem with ebay is waiting around for one to show up on there.
06-22-2005, 10:04 AM | #18 | |
Rock Crawler Join Date: Jul 2004 Location: Mt.View CA
wooow,thats a bling blinged bruiser. I also agree loose the side plates...... | |
06-22-2005, 10:53 AM | #19 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
