06-21-2005, 05:19 AM | #1 |
Pebble Pounder Join Date: Nov 2004 Location: Thomaston, CT
| which link location????
Doing the normal 4 link on my TLT. The links that converge will be mounted above the servo, and go out to the chassis. The height distance on the axle is probably 2 or so inches between links. Should I mount them on the same spot on the chassis, or have them the same vertical distance apart as what is on the axle?
