03-23-2008, 08:14 PM | #1 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
| RC4WD Copperhead chassis
I had the chance to build up an RC4WD Copperhead chassis. Here are some of the details. TLT Axles w/fat rock C's and CVD's in the front. MSD wideners RC4WD punisher shafts Delrin Links Paul's EZ's rear axle truss Traxxas big bore shocks RC4WD R2 Dig tranny Holmes Hobby Crawlmaster Quark 33 Pro car ESC (2) Tower Pro 945 servo's. Some old school RD400 beadlocks and Losi Claws Got the chassis and built it up. Very nice work on this one. The Powder Coat is perfect. The R2 went in without any problems. Links and shocks mounted up great. Adding the extra shock mounts was a good idea. Really liked the body panels that came with it. I added a little flair to mine. As I said, everything went together really well. Had a small issue with the nuts for the dig servo being to large. Small amount of time with the dremel and the servo went in perfect. I e-mailed RC4WD and they said they would look into it. The nuts outside diameter is too big. I would have to say that RC4WD is doing a better job at getting things right. This chassis is proof of that. Here are a few shots I took. Used the lathe motor for mock up. I was going to put a Holmes Hobbies Cobalt puller in this, but it doesn't fit. Lathe motor and other brushless motors will. Here is the tranny and servo mounted in. On to the next post. Last edited by Racer4Life; 03-23-2008 at 08:29 PM. |
03-23-2008, 08:23 PM | #2 |
Got the links made and installed. Not much need for those photo's. It was smooth sailing for the link mount up. Sprung rear. Droop front. Shoots on the rocks. On the rocks the chassis did very well. Down off rocks seemed very simple, up over some breakovers was a bit of an issue. I am going to work on the set-up a little. The lower bottom plate helps, but hurts a little too. I still need to find a good spot for my battery. I will probably build a pack for the front axle. My Lipo didn't fit anywhere good, so for testing I sit it beside the R2. |
03-23-2008, 08:29 PM | #3 |
RCC Addict Join Date: Apr 2004 Location: 5280
Looks good Tom, cant wait to see it |
03-26-2008, 06:40 PM | #4 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
03-29-2008, 04:53 AM | #5 |
Quarry Creeper Join Date: Jul 2007 Location: EWA BOUND
Thats gangsta |
04-02-2008, 04:26 PM | #6 |
Quarry Creeper Join Date: Mar 2006 Location: Eastern North Carolina
Looks real good. Does the front edge of the bottom skid plate get hung up?
04-29-2008, 06:50 AM | #7 |
Landy mad Join Date: Jun 2005 Location: Newcastle, England, UK
Racer4life, Did you use the stock links or make your own? Edit: Noticed in your first post....Delrin links, woops I'm having issues with lack of movement and trouble with lengths with the stock links Last edited by wallaz; 04-29-2008 at 02:08 PM. Reason: re-read first post |
04-29-2008, 08:39 AM | #8 |
Rock Crawler Join Date: Jan 2007 Location: Do I look like a freaking people person?
How are those Punisher shafts? I have heard some people on here complain about them.
05-06-2008, 09:44 PM | #9 | |
Thanks | |
05-06-2008, 10:51 PM | #10 |
Rock Crawler Join Date: May 2007 Location: Valdosta
| I have to agree with Racer on the punisher shafts. I have 1 set that have been swapped around on a couple different rigs and I love them, you just can't get too extreme an angle with them or they lope. Another hint for people using them with TLT axles, grind about 1/16-1/8 inch off the end that you are attaching to your axle, the set screw will grab you axle pinion gear shaft alot better.
05-11-2008, 11:23 AM | #11 |
Quarry Creeper Join Date: Aug 2006 Location: Baumholder
How long are all of your links, as in top and bottoms front and back
04-29-2009, 09:30 PM | #12 |
Rock Crawler Join Date: Jan 2009 Location: east bay
How's that tranny holdin' up?
