04-18-2008, 11:53 AM | #1 |
Newbie Join Date: Mar 2007 Location: Sheldon
| SW2 Shock setup?
Hey all, I have an SW2 from Bender Customs that I really enjoy. It has worked very well for me. I am having a problem with my shocks though. I am using T-Max shocks and they are not flexing as well as I would like. I have red springs on the back and light green ones on the front but I'm not sure if the ones on the front are long enough. I bought them over a year ago and can't remember who makes them. I'm thinking of buying some RC4WD X11s or X10s but I'm not sure which ones will work for length. Is there a setup that someone has used that they can share with me. Maybe I just need to rebuild them with lighter shock oil and longer, softer springs. Part numbers would be appreciated if you have them. I'm headed out tomorrow for some crawling with friends and right now the flex is embarrasing. Please help JulianXJ |
04-18-2008, 12:26 PM | #2 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
Which T-Maxx shocks are you using? I have been using the same aluminum Traxxas big bore shocks for over 2 years and they work great! If you are using the cheaper plastic ones I would get the aluminum ones. The newest and hottest shocks out are probably the 4" Losi ones and they are threaded for easier adjustment. I have been using the Losi white springs in the front and a combo of springs for the rear to dial out torque twist and body roll. Also use light oil in the front and the right rear shock and step up the weight for the left rear to help with these as well. Hope that helps... To really get the most from the SW2 check out Benders Build thread and read as much of it as you can, He usually puts his setups in all his build threads. |
04-18-2008, 12:42 PM | #3 |
I'd recommend using Losi pink, yellow, or white buggy springs. I have always used pinks (painted black) with Maxx shocks on my SW2 with great results. Whites are very popular. Red Maxx springs are too stiff for a 2.2 rig. |
04-18-2008, 12:59 PM | #4 |
RCC Addict Join Date: Feb 2007 Location: MS Coast
I run Losi whites on the front and yellows on the rear of my SW2 with the plastic maxx shocks
04-25-2008, 02:46 PM | #5 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
I have always ran the stock T/E Maxx shocks with Losi whites on front and yellows on rear . look thru my build tread of Whadafuxup (SW2 build) you will see many flex shots from comp pics . whadafuxup SW2 build That set up served me well till I built my new SW3 .
