07-08-2005, 09:36 AM | #1 |
Newbie Join Date: Jun 2005 Location: Kite, GA
| My TLT pics That's with an old Pro-Line Jeep body, Imex Pullers, Mtroniks ESC, bearings, stock chassis(cut a lot), Pede tranny and a ~12" wheelbase. I'm using the stock shocks, so articulation SUCKS, but I love the scale look umm, that's it. Thanks to all the guys who helped me out in some of my threads, all that stuff... -Beeni Last edited by BeeniDAmeeni; 07-08-2005 at 09:38 AM. |
07-16-2005, 01:04 PM | #2 |
Okay, some of my pics got deleted... no articulation pics... but I did manage to hack a servo to turn 360 degrees... and then mounted it on the front axle... and then found a small rope/string and a hook... umm... so what does that mean? Winch! I used a small twine for rope... it reaches about the length of the truck: It operates off an old switch made for two AA batteries... and 2.5 volts isn't enough for me, so I chopped it up and made room for a 9 volt... Then I took all of the electronics out of the S3003 servo and chunked 'em. I kept the motor, soldered the ends from the old switch, then put it all back together... and viola!!! It's powerful enough to pull the truck when the motor isn't engaged... :eek: Now here is where I need some help... does anyone know of any really scale looking body that would fit? The truck has a 12" wheelbase(Maxx sized bodies work well) I was looking at the Juggernaut bodies... but I don't know their wheelbase... ? I don't mind the CJ body I have now... but I need a new look for my new truck... I'm using "recycled" bodies now... lol Any suggestions? OH, and BTW, it needs to be something that would look good with lights and a rollbar... |
07-16-2005, 05:38 PM | #3 |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
Why not get the bronco body from radio shack? Its for the truck called the "Mauler"
07-16-2005, 08:36 PM | #4 |
RCC Addict Join Date: Dec 2004 Location: Central NY
lookin good
07-17-2005, 10:43 AM | #5 | |
Quarry Creeper Join Date: Jan 2005 Location: Crafty mexicans and your glass candy...
heres a link to some pics http://s8.invisionfree.com/Scale_4x4...showtopic=1768 | |
07-18-2005, 04:48 PM | #6 |
Thanks! I think I might just stick with the Jeep body at the moment... I need to put some weight in the tires... How many of you guys notice any problems with using BB's or other round lead weights? I'm not sure how it will work out, or how it helps at all... ? |
07-18-2005, 05:14 PM | #7 |
Quarry Creeper Join Date: May 2004
adding weight to the tires puts weight down low. It helps keep the tires planted, therefore giving more traction. Only thing is it will make it harder on your motor to turn the tires, since its more mass. But if you're already geared low for crawling you should have any problems unless you plan on fillin every empty space in your tires with lead. (that was a joke) i'm not sure what motor you're running, but if it seems like to you that it already has some problems on the terrain you run your truck on, i wouldnt add to much weight before you get a stronger motor, but if your motor is havin no trouble at all then go ahead at it. Last edited by pedesrule; 07-18-2005 at 05:16 PM. |
07-18-2005, 05:42 PM | #8 |
More weight for the servo to turn also.
07-18-2005, 09:50 PM | #9 |
I am using a Hobbico/Cirrus High torque servo, so that's not much of a problem. I'm geared at 14/90 using those big tires, and I have a 12 volt Johnson motor in their... I'm sure with extra weight, and maybe a 12t pinion, I should do just fine. So do BB's do Okay, or are there any other alternatives? |
