07-12-2005, 03:28 AM | #1 |
Quarry Creeper Join Date: May 2005 Location: lost in vintage tamiya land.
| Bruiser driveshaft question.
Is it correct that i can shorten one of the jugg 2 driveshafts for the front and the rear one bolts in? I have some max sliders but they are too big to use without smaller yokes. Should i just switch to the smaller tamiya yokes and use the sliders? I don't have much suspension travel right now but i plan to use jugg2 leaves that i'm gonna rework to give me better travel then stock leaves hopefully. If i use the max sliders i'm guessing i can't buy just the small yokes by themselves from tower correct?
07-12-2005, 10:17 AM | #2 | ||||
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
The gold drive shaft parts are from my Mounty, then silver and black are from my TXT. Quote:
http://www2.towerhobbies.com/cgi-bin...?&I=LXJG59&P=7 Quote:
Don't bother trying to get crazy travel out of the leafs, run it like mine and you will have a blast lifting tires in the air. Quote:
07-12-2005, 10:22 AM | #3 |
I saw where thorbob used jugg yokes with max sliders and it worked good for him. I don't have the original drive shafts at all though and i need to find the best way to get some that fit right. The jug shafts i've been told will fit but the front one has to be shortened. The max sliders will fit with jug yokes and i guess your saying regular old pede sliders will fit with no chages at all? I think i'll try to get those if tower has them in stock. I know there bad about not stocking pede parts. I was going to try and rework the jug springs to give decent travel. Not a whole big bunch. I was thinking of trying to de arch them somehow maybe by heating. |
07-12-2005, 10:33 AM | #4 |
I am sure you can get max slider to work somehow. Anything is possible, I just don't see the point. The stampede slider are plenty strong and look more scale in size then the max ones. You just need to get the steel yokes and some stampede sliders and you will be set. If you want to go with the stonger jugg ones then work on those after you play with the stampede ones since they are so much easier. |
07-12-2005, 10:49 AM | #5 |
Yeah i was just saying the max ones because i already have them. thanks for the info
