06-03-2008, 05:51 PM | #1 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
| WCCC Top banana build
My dad has been running his prototype Banana rig for a few months now, with basically my leftover spare parts and running gear... Pede trans, TQ3, stock axles, etc. He's been driving a lot more lately and putting in some respectable comp finishes, so it was time for a rebuild. With the West Coast Crawler Challenge less then a month away, we decided to go full-out and build the ultimate comp-worthy rig. With the pede trans out of the way, there's plenty of room for the Ax-10 trans and VF dig. Even with the 2" skidplate, everything tucks nicely inside the chassis. Up next was the links... We went with axial 70mm threaded links for the lowers, and 65mm links for the uppers. Using axial's offset rod ends from the AX80005 linkage set, we're able to triangulate the lower links a lot more without binding, and eliminate a lot of axle steer. On to the shocks... The fronts are Revo's set up 50/50 with 60wt. oil and use cut TLT springs on both sides of the shock piston. This keeps the front end from unloading to much on the big vertical stuff, but still allows for some decent flex. The rear shocks are Revo's with a cut down TLT spring on top of the piston. The spring is cut very short, maybe 1/4 of the length of a stock TLT spring. We used 100wt. oil, but only filled the shock about halfway up. As the suspension twists and moves further from the chassis, the shock piston hits the oil and slows down dramatically. It makes for a very smooth cycyling suspension that reacts quickly for big vertical launches, but is slow and controllable in the twisty crawling stuff. We also decided to step up the electronics. Thanks to RCP, my dad will be competing in style with a DX3R, and crawling smoothly with a Mamba Max/55t and 3s lipo Losi Rock Claws will provide plenty of traction to get this rig up and over anything. So far in two days of testing, this rig has easily conquered everything we've thrown at it. Its by far the best handling rig I have ever driven. Somehow, its making MY comp rig look pretty bad... but I haven't started my WCC updates yet Stay tuned for more updates, and come see this rig in action at the West Coast Crawler Challenge at Lake Wohlford June 27-29th Last edited by Del Monte; 06-08-2008 at 01:54 PM. |
06-03-2008, 06:58 PM | #2 |
Quarry Creeper Join Date: Feb 2008 Location: no more lockers
sweet rig , clean design nice and simple cheers
06-03-2008, 07:17 PM | #3 |
Rock Crawler Join Date: Apr 2008 Location: Rancho Cucamonga
| top banana
Your dads rig is looking good Jake. What do you think helped the rig the most compared to his old banana set up?
06-03-2008, 07:37 PM | #4 |
Pebble Pounder Join Date: May 2008 Location: SoCal
Looks really great man. Sweet Setup.
06-03-2008, 07:59 PM | #5 |
| Moving the lower links in helped a lot. We're trying the parallel uppers setup in the front too, and so far it seems to work great. I may try that setup on my rig too.
06-03-2008, 08:49 PM | #6 |
06-03-2008, 09:05 PM | #7 |
RCC Addict Join Date: Jul 2006 Location: So Cal USA
Looks good Jake... giving me some reference on my build |
06-04-2008, 07:52 AM | #8 |
varcor.org Join Date: Aug 2005 Location: 757
nice job... any issues with the chassis side lower link bolts bending or coming loose? looks like alot of force/leverage would occur there...
06-04-2008, 01:03 PM | #9 |
Quarry Creeper Join Date: Jan 2006 Location: San Diego
Jake looking good One ? how much weight in the wheels
06-04-2008, 01:17 PM | #10 |
no talent hack Join Date: Feb 2007 Location: Redwood City
instead of you sending me that other chassis, can i just send you a box of parts and have you put it together? pretty please? |
06-04-2008, 03:21 PM | #11 | ||
The fronts are around 18oz. total for the wheel/tire/weights, and the rears are around 10oz. Quote:
Building them is half the fun | ||
06-04-2008, 04:58 PM | #12 |
| ride height
Hey whats the ground clearance on that rig?
06-04-2008, 05:21 PM | #13 |
06-04-2008, 06:34 PM | #14 |
| Ya right now i'm trying a little higher ride height about 3.25 in the rear and 3 in the front. It sidehills great still but i'm not to happy with the ups and downs as much. I think i'm gonna try some 3 inch shocks and lower to about 2.5-2.75 and try it.
06-05-2008, 09:34 PM | #15 |
06-06-2008, 03:07 PM | #16 |
Rock Crawler Join Date: Jul 2007 Location: central PA
Last pic is cool I have been impressed with the Banana's and the various videos I watched. How would you compare this truck to your old Falcon comp rig? I remember reading good things about that truck and alot of wins |
06-06-2008, 03:18 PM | #17 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
Looks great Jake! Btw, did you get my message about the stickers? |
06-06-2008, 03:49 PM | #18 |
Quarry Creeper Join Date: Jul 2006 Location: Apple Valley, CA
Look'n great Jake!.....Now we've got Mike to worry about too??!!:-(..............
06-07-2008, 11:38 AM | #19 | |
This rig cruised through last night's Friday night fights with a perfect score... and a new fanclub Prepare for world dominaton | |
06-09-2008, 03:53 PM | #20 |
Pebble Pounder Join Date: Feb 2006 Location: Evanston
Hey Jake Do you like the rockshocks or the Revo shock set up better ? Did you get those 2 things we talked about in yet? |
