Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: What about this for a tranny?
Old 07-23-2005, 07:31 PM   #1
Default What about this for a tranny?
http://cgi.ebay.com/ws/eBayISAPI.dll...ory=44022&rd=1
would it work?
TLT based
Smurf is offline   Reply With Quote
Old 07-23-2005, 08:17 PM   #2
Maybe, but I'd probably take this one first...
http://cgi.ebay.com/ws/eBayISAPI.dll...ory=44028&rd=1
Plays_with_Toys is offline   Reply With Quote
Old 07-23-2005, 08:21 PM   #3
they half shafts were always easy to mess up. I'm not sure it they would hold up to the abuse of larger tires and rock crawl'n.
BlackSheep is offline   Reply With Quote
Old 07-23-2005, 09:37 PM   #4
That first trans you showed is out of a 20 year old tamiya kit (the brat, blackfoot,etc), it is a big trans and very hard to find parts for. Stick to something that is still being made, you will appreciate it when you shell a gear
RD400 is offline   Reply With Quote
Old 07-24-2005, 02:48 PM   #5
would an RC10 tranny work?? its got joint cups for T-bones
Nova is offline   Reply With Quote
Old 07-24-2005, 04:29 PM   #6
dude just use a pede tranny parts are soo redaily available for it. pluss its made for the traxxas half shafts! not like a losi or an AE tranny.
nd4spdbh is offline   Reply With Quote
Old 07-24-2005, 06:14 PM   #7
Stealth tranny's have been used. I hear they are a very strong tranny with the hardened inner gears.
Losi XXX tranny's can have sliders. I am still trying to find my instruction manual to get the part numbers.
Old 07-24-2005, 08:42 PM   #8
tru
im using alosi trans and i used tmaxx slidders you just have to drill out the yoke to fit the cup in the yoke and drill the cup to screw in the pin
tru is offline   Reply With Quote
Old 07-25-2005, 01:30 PM   #9
i am using a ae tranny and it works really well
roadkill424 is offline   Reply With Quote
Old 07-27-2005, 11:44 AM   #10
roadkill
which tranny did you use? or are they all the same?
hows the performance of it?
are you using sliders? if so how did you put them on?
romeo26 is offline   Reply With Quote
Old 07-28-2005, 03:28 PM   #11
I just bought this stealth b2 tranny from RCU, http://www.rcuniverse.com/market/item.cfm?itemId=116722
Shouldn't be too hard to adapt it to fit the stock chassis? Also gonna go with lathe motor and 9/84 gearing.
Anyone run a similar tranny? Does it perform well?
sean_lv_crawler is offline   Reply With Quote
Old 07-28-2005, 03:37 PM   #12
NO, NO don't use the black foot tranny. The axles strip, the diff gear strip they are lemos.
jwrape is offline   Reply With Quote
Old 08-02-2005, 09:35 PM   #13
i used the b4 tranny. i used a axle from a maxx, and the part for the roll pin goes into the tranny and drill a hole the all of it. it wasnt easy because of it being made of harded steal. but it works great.
Old 08-03-2005, 12:27 AM   #14
I used a stealth tranny in Fungus ( http://www.rcpics.net/img/61865 ). I have another rig with a pede in it aswell. In all honesty I like the stealth better. I hollowed out some traxxas yokes and drilled some holes for pin mounting ( http://www.rcpics.net/img/61632 ) and the thing works great (I'm not down with searching for dogbones.) The whole thing is half the weight of the pede and the gears hold up amazingly. I'm running a 15/87 gearing ( great wheels speed and perfect torque with a 55t of course.) Hope thats in any way helpful.
Terry
CrawlnSlow is offline   Reply With Quote
Old 08-12-2005, 07:20 PM   #15
Terry
What exactly did you do to the pede yokes to get them to fit? I am not following you.
And How did you lock the inner diff in the b4 trans?
Old 08-12-2005, 07:39 PM   #16
Gold Star Baby Momma!
b3 tranny locked down tight with jbweld, just clean the diff and smear in a liberal amount of jbweld .
Tuffguy is offline   Reply With Quote
Old 08-12-2005, 08:48 PM   #17
along the line of the b3 or b4 trans, i got a couple of duratrax evader bx transmisions and they look similar the the b's. i was wonderin if it would be close enough to do the same trick too with the yokes??
Amaxx is offline   Reply With Quote
Old 08-12-2005, 09:00 PM   #18
tru
you need you use tmaxx yokes and sliders
