Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: jugg springs
Old 07-27-2005, 05:37 PM   #1
Default jugg springs
does anyone know how flexxy the juggernaut springs are
i am wanting to turn my tlt into more of a scale rig and i want to use jugg springs instead of a 3 or 4 link setup
XCUTIONER is offline   Reply With Quote
Old 07-27-2005, 05:39 PM   #2
Should be pretty flexxy, just mount it and lower it ;)
Nova is offline   Reply With Quote
Old 07-27-2005, 06:56 PM   #3
reason i am asking is becasue i found the springs at tower for $12 a pair
rc4wd.com has the for $40 a set
only thing different is the rc4wd comes with stainless steal screws and locknuts
Old 07-27-2005, 08:03 PM   #4
the full juggy leaf pack is not flexible at all infact with about 10 pounds on top of them they just start to flex so you have to use only a 1 or 2 of the leafs depending on the weight/ size of you rig
Will is offline   Reply With Quote
Old 07-27-2005, 08:39 PM   #5
i didnt read right, i thought you were gonna use a different shock/spring, and didnt read "Instead of"
It should be a nice scale look, but for crawlin, that isnt the best
Old 07-27-2005, 09:51 PM   #6
Yeah, there was a TLT from the ORCRC guys running leafs. Try searching for flatbed toyota. I know its a flatbed something. King Cobra is running similar springs in his 1:6 scale rig, and it has no flex, even with all the weight. So, maybe run a single leaf, or maybe two, like was said.
Oh and sigp232 has a rig with leafs. You can search for his post here, and he's got a more thorough posting on scale4x4.
Plays_with_Toys is offline   Reply With Quote
Old 07-27-2005, 10:01 PM   #7
Yeah those springs are wicked hard. Maybe using 2 of them in some combination like top and middle or top and bottom spring but then you have to watch out on torque twist. I S'ed a set of mine in the rear before adding traction bars to tame the axle wrap.
Thundermaxx is offline   Reply With Quote
Old 07-28-2005, 02:02 AM   #8
if you wanna see amazing scale work i would go check out www.scale4x4rc.us some of the guys here also have buildup threads in the 2.2 section of that website
Old 07-28-2005, 06:08 PM   #9
i figured that the weight of the springs would be way to much and did plan on using just the main spring or a combination
that forum is the reason i desided to go for the scale look or at least something close to it
this is one of the threads that got me thinking
http://s8.invisionfree.com/Scale_4x4...showtopic=1757
