07-29-2005, 01:08 AM | #1 |
Rock Crawler Join Date: Feb 2004 Location: Astoria, Oregon
| VMG question
I wanted to know if I could run a esc like the rooster with the fireball motor?
07-29-2005, 01:45 AM | #2 |
Quarry Creeper Join Date: Mar 2005 Location: Pleasant Grove
You can run it, but full size esc's are big on a mini giant.
07-29-2005, 09:47 AM | #3 |
Thanks for the info, I would run a mini esc like the spy or a lrp one. Now my other question, when running a esc like this what should I do for a battery pack? Thanks again for the help.
07-29-2005, 10:28 AM | #4 |
any battery that you want. try a 6 cell 1100 mah pack.
07-29-2005, 10:31 AM | #5 |
RCC Addict Join Date: Nov 2004 Location: Redding, CA
here is my used to be vmg. http://tinypic.com/view/?pic=9krtk6 i used a hitec hfxr speed ccontroler and stock vmg motor. for a batery i used a mini-t 6 cell pack. but i am going to use a venom hex pack on my new vmg. |
07-29-2005, 11:04 AM | #6 |
Alright I'll go with a mini-T battery pack. As for the venom hex cell, I've heard those burst into flames....
07-29-2005, 11:17 AM | #7 |
well i've never seen a hex pack burst into flames before, but they were being used on other vmg crawlers, so thats probably why. (low amp draw). but they give a longer run time with more pawer. and they can be mounted easily. |
07-29-2005, 12:00 PM | #8 |
i saw a few that didnt take the upgrade motor without bearings. the amp draw was too high for them and the crappy battery "bars" just went up in smoke. the esc's are not very good either. i fried one quick fast and in a hurry.
07-29-2005, 12:15 PM | #9 |
Rock Crawler Join Date: Jan 2005 Location: and OR. if . . . . Gone Fishin :p :b :p
Tons of the Hex Packs went up in Flames, mine did while charging. I've had great luck with the stock ESC, I ran an 8 cell in my crawler all the time, and even a 3-cell lipo a couple times with no problems. |
07-29-2005, 06:04 PM | #10 |
Pebble Pounder Join Date: Mar 2005 Location: Utah
I've owned two Hex packs and had no problems. You have to have bearings installed and only charge at 1 amp, no problems if you use them correctly. David |
