09-01-2008, 01:58 PM | #1 |
Newbie Join Date: Nov 2007 Location: HUEYTOWN
| installing a pead tranny in a tracer installing a pead tranny in a tracer I have widened the center with bake line. and mounted the tranny to the side . picks to come Last edited by mrodgersbmx; 09-02-2008 at 09:16 PM. |
09-05-2008, 07:49 PM | #2 |
Newbie Join Date: Jan 2005 Location: the 757 (Va Beach)
Ahhh... I see what you did there!! Did you have to cut into the chassis at all?? I've been debating on hacking up my Tracer to fit a Pede or R2 trans. (or just buying a new chassis with a lower cg)
09-05-2008, 10:08 PM | #3 |
No, just made sure it was wide enough. It works ok my only prob. is I changed my shock location and it has a lean . I am working that.
09-06-2008, 08:25 AM | #4 |
Newbie Join Date: Feb 2007 Location: Earth
What're you going to do for a skid plate?
09-06-2008, 10:44 AM | #5 |
prob. a peice of a aluminum ,derlin don't know wich yet.
09-09-2008, 03:57 PM | #6 |
this is the video seeing how the tranny works. i know that the suspention needs help bad. http://www.youtube.com/watch?v=fS0pOTwOWZY Last edited by mrodgersbmx; 09-09-2008 at 04:01 PM. |
09-22-2008, 06:55 PM | #7 |
Newbie Join Date: Sep 2008 Location: albuquerque
can you give me detailed instuctions on how you installed your pede tranny cause i have one and i want to put it on my tracer chassis |
09-23-2008, 08:58 PM | #8 |
I will do my best. It's not to hard I just had to first locate the tranny between the links. To beable to mark & drill holes in the gear side of the frame. You will need to make some mods. to tranny to clear links. Also have to make some spacers to put under it. Than I used brake line to widen frame in middle , than used orig. frt. & rear tube pull it back in .
09-24-2008, 10:22 AM | #9 |
ok thanks. i was just unsure cause i dont want to mess up my pede tranny. im on a budget. another question. when i put the tracer kit all together it articulates fine but when i put on my e max shocks they are extreamly stiff and its not the springs cause i can take then off and the same thing happens. i cant figure out how to install my shocks so they will work. did you have the same problem? |
09-27-2008, 04:43 PM | #10 |
Just changed all the links .went to high clearance ones . having to make alot of changes. i'll post pic's when i get some.
